How to find out current in circuit?
Discussion in 'Electronics Homework Help' started by vead, Jul 25, 2016.
  1. vead
    vead
    Nov 27, 2011
    468
    14
    Hello
    How to find out current i in circuit. What should I have to apply kcl or kvl.
    I always confused, I don't understand. Where I need to apply kcl or kvl
    vead, Jul 25, 2016
    #1
    1. Advertisements
  2. vead
    7,952
    1,448
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    You'll need both types of equation and combine them in the right way. Use sum of currents for the top center node, you know the voltage across the network from top to bottom etc.
    Once the set of equations has been set up, solve for the unknowns.
    Harald Kapp, Jul 25, 2016
    #2
    vead likes this.
    1. Advertisements
  3. vead
    vead
    Nov 27, 2011
    468
    14
    OK how do you know that we need to apply both type of equation. Actually when I saw complex circuit I don't understand what I need to apply kcl or kvl. How to know that I have to apply kcl or kvl or both kcl, kvl?
    vead, Jul 25, 2016
    #3
  4. vead
    7,952
    1,448
    You have to apply whatever it needs to set up the system of equations such that you can solve for the unknowns. Sometimes one method or the other may suffice, at other times you'll need both types of equation. There is no general rule.
    #4
  5. vead
    vead
    Nov 27, 2011
    468
    14
    KCL at node a
    I2 = i+i1
    I2=i+5
    Using kvl in abcd loop
    8=5i2+5
    i2=3/5
    i+5=3/5
    i=-4.5A
    Is it correct?
    vead, Jul 25, 2016
    #5
  6. vead
    7,952
    1,448
    The numbers are good.
    I strongly urge you to always use numbers + units in your equations. For example:
    I2 = 3/5 ?? µA? mA? A? ...
    Keeping tabs on the units helps you to verify the plausibility of your equations. If, for example, you come across an equation R=3V/2V you know that this van't be correct becasue the unit of resistance (R) is Ω, which is Volt/Ampere.
    #6
    vead likes this.
  7. vead
    vead
    Nov 27, 2011
    468
    14
    OK next time I will remember
    How to find out the resistance R?
    vead, Jul 25, 2016
    #7
  8. vead
    7,952
    1,448
    In the same way: set up the equations, solve for R.
    Show us your effort.
    Also, I will move this thread to the homework section where it belongs, I think.
    #8
  9. vead
    vead
    Nov 27, 2011
    468
    14
    From the circuit, I can't find out the current or voltage across the R because R is unknown
    I think the possible conditions
    Current through 1Ω
    I=50v/1Ω
    I=50/1 A
    voltage across 1Ω
    V=50A*1Ω=50v
    Now how to find out current and voltage for 2Ω
    vead, Jul 25, 2016
    #9
  10. vead
    7,952
    1,448
    Doing a quick calculation shows that this diagram has no single solution. You can express voltage across the 2 Ω resistor and current through it only as a function of R. As in V(2Ω) = f(R).
    Or vice versa.
    Unless one other current is given. E.g. current through R as indicated by the arrow on the wire leading to R.
    #10
  11. vead
    vead
    Nov 27, 2011
    468
    14
    What do you mean?
    Arrow is indicate the direction of current, not the value of current. If I apply the kcl at left node of 2 Ohm resistor. I can't set the equations because there are two unknown values of current
    vead, Jul 25, 2016
    #11
  12. vead
    Ratch
    Mar 10, 2013
    912
    269
    You are completely lost. You have an independent voltage source and an independent current source. The R resistor can be any physical value you can name. Unless you specify what the current or voltage is present across or through the resistor, no specific value for R can be calculated.
    Ratch
    Ratch, Jul 25, 2016
    #12
  13. vead
    7,952
    1,448
    As Ratch elaborated: You can chose any value of R and will get a resulting distribution of currents and voltages whcih can be expressed by a set of equations as in V(2Ω) = f(R) where f(R) is a rational function of R.
    Harald Kapp, Jul 26, 2016
    #13
  14. vead
    vead
    Nov 27, 2011
    468
    14
    Let's suppose voltage across R is V
    Then current throw R resistor should be Ir=V/R
    current I1=4A given
    Current through the 2 ohm resistor is I2
    Apply kcl
    I1=Ir+I2
    4A=V/R+(V-50)/22
    If the current through 1ohm resistor is I3
    I4 is current from 50 volt source
    Again from the kcl
    I2+I4=I3
    (V-50)/2+I4=50
    Here I have two equations but I don't understand how to solve
    vead, Jul 27, 2016
    #14
  15. vead
    Ratch
    Mar 10, 2013
    912
    269
    You are getting careless in your proofreading.
    The I3 current present is 50 amps. After all, it has 50 volts across 1 ohm, doesn't it. You show 2 equations and 3 unknowns. Try to solve for only the voltage V across R, then you can easily find the currents elsewhere in term of R. Hint: Use the superposition method.
    Ratch
    Ratch, Jul 27, 2016
    #15
  16. vead
    vead
    Nov 27, 2011
    468
    14
    I tried to set equations
    4A=V/R+(V-50)/2
    (V-50)/2+I4=50
    Is it correct?
    From the equations, I don't understand how to find out voltage across R
    vead, Jul 27, 2016
    #16
  17. vead
    Ratch
    Mar 10, 2013
    912
    269
    You already did. 4=V/R+(V-50)/2=====> V=58 R/(2+R). Pick any R and the voltage can be calculated. Do you have a sense of what is going on?
    Ratch
    Ratch, Jul 27, 2016
    #17
  18. vead
    vead
    Nov 27, 2011
    468
    14
    Do you mean, the value of R may be anything 2, 4, 8 ohms etc. I have to take one value then I have to find voltage and current through R
    I did as you said
    If R= 2 ohms then voltage across 2 ohms resistor is 29 volts
    vead, Jul 27, 2016
    #18
  19. vead
    Ratch
    Mar 10, 2013
    912
    269
    Yes, that is correct. The independent current source is going to output 4 amps regardless of what the value of R is. Likewise, the independent voltage source is going to output 50 volts regardless of what R is. All the other resistors are fixed in value. The only way you can change the voltage across R, or the current through R, is to change the value of R. As an extreme case, consider R = 0 . The equation you found gives a voltage value of 0 volts. Makes sense, right? Now, consider R = infinity. The equation gives a value of 58 volts. Once you know the voltage across R, you can find the currents in the rest of the circuit.
    Ratch
    Ratch, Jul 27, 2016
    #19
    vead likes this.
    1. Advertisements
