How to convert Sallen-Key Low pass filter to Signal Flow Graph
Discussion in 'Electronics Homework Help' started by Edward1212, Oct 9, 2017.
  1. Edward1212
    Edward1212
    Oct 9, 2017
    [​IMG]
    #1
    1. Advertisements
  2. Edward1212
    LvW
    Apr 12, 2014
    584
    140
    Bremen, Germany
    The circuit consists of a fixed-gain amplifier (opamp with R3, R4) and a positive feedback function. Hence, where is the problem to find the signal-flow graph?
    LvW, Oct 9, 2017
    #2
    1. Advertisements
  3. Edward1212
    Audioguru
    Sep 24, 2016
    1,800
    415
    There are two RC lowpass networks, R1 and C1 and R2 and C2. Each RC network has an output of -3dB at the cutoff frequency.
    Actually, the positive feedback occurs only near the cutoff frequency so that the -6dB response is boosted to be -3dB and the cutoff is sharp instead of droopy.
    Audioguru, Oct 9, 2017
    #3
  4. Edward1212
    LvW
    Apr 12, 2014
    584
    140
    Bremen, Germany
    No - it is obvious that the feedback network consists of a band pass (highpass C1-R1, lowpass R2-C2).
    As a consequence, there is no lowpass -6dB response.
    LvW, Oct 9, 2017
    #4
  5. Edward1212
    Audioguru
    Sep 24, 2016
    1,800
    415
    I disagree. C1-R1 is a lowpass, not a highpass.
    If C1 connects to ground instead of the the opamp output then there is no boost and the output at the cutoff frequency will be -6dB and the slope will gradually be 12dB per octave.
    Audioguru, Oct 10, 2017
    #5
  6. Edward1212
    LvW
    Apr 12, 2014
    584
    140
    Bremen, Germany
    We are discussing the FEEDBACK network. Hence, you have to look into the circuit from the opamp output.
    You cannot deny that - in this case - the feedback network resembles the well known highpass-lowpass CR-RC bandpass characteristic. This is a well-known property of a positive-gain Sallen-Key lowpass.
    LvW, Oct 10, 2017
    #6
    Arouse1973 likes this.
  7. Edward1212
    Audioguru
    Sep 24, 2016
    1,800
    415
    The bandpass circuit occurs only near the cutoff frequency to boost the response so that it has flat levels at low frequencies, -3dB at the cutoff frequency instead of a droopy -6dB and a sharp 12dB per octave slope at higher frequencies. Above the cutoff frequency both RC networks are lowpass filters.
    #7
  8. Edward1212
    LvW
    Apr 12, 2014
    584
    140
    Bremen, Germany
    I don`t understand your position.
    A bandpass is a bandpass - full stop.
    Just one question, which can be answered with yes/no:
    Do you agree that - between the ouput pin and the non-inv. input of the opamp - there is the classical four-element ladder network C1-R1-R2-C2 ? And this is the well known RC-bandpass.
    How can you say that "Above the cutoff frequency both RC networks are lowpass filters"?
    At first, we don`t have two RC-networks because you are not allowed to separate them, because they influence each other.
    Secondly, the series cap C1 - of course - has highpass properties. I don`t think that you will argue against this.
    LvW, Oct 11, 2017
    #8
  9. Edward1212
    Audioguru
    Sep 24, 2016
    1,800
    415
    I see the circuit as two lowpass RC networks at frequencies above cutoff like this:
    Audioguru, Oct 11, 2017
    #9
  10. Edward1212
    LvW
    Apr 12, 2014
    584
    140
    Bremen, Germany
    OK - I know what you mean. But that does not answer the question.
    The question concerns the corresponding signal-flow diagram (which shows forward and backward ways.).
    That is the background we are speaking about FEEDBACK.
    And - it does not matter how the circuit looks like without feedback.
    It is a fact that the Sallen-Key lowpass has a feedback function that resembles a bandpass.
    This is the background for realizing a complex pole pair.
    LvW, Oct 11, 2017
    #10
    1. Advertisements
