How to connect op amps in parallel
Discussion in 'General Electronics Discussion' started by Looee, Jan 7, 2017.
  1. Looee
    Looee
    Nov 8, 2016
    4
    We are trying to put 5 different signals on a 120 volt power line. We are running each signal through an op amp to increase the amplitude. We connected the output of all the op amps together. However, this causes the amplitude of the signals to attenuate. Is there a way that we can connect all the signals together without any attenuation?
    Looee, Jan 7, 2017
    #1
    1. Advertisements
  2. Looee
    AnalogKid
    Jun 10, 2015
    2,121
    595
    Ohio - GMT-5
    Yes.
    ak
    AnalogKid, Jan 7, 2017
    #2
    Arouse1973 likes this.
    1. Advertisements
  3. Looee
    7,056
    1,463
    Worcester, MA
    To be a little more helpful, lookup summing amplifier.
    BobK, Jan 7, 2017
    #3
  4. Looee
    duke37
    Jan 9, 2011
    4,928
    642
    Derbyshire. UK
    You can sum with resistors to a common point. If you make this point at the -input of the op-amp, you will have a virtual earth amplifier. The current going into this common point will carry on through the feedback resistor and so will generate a polarity reversed voltage. One input will not affect any other input.
    duke37, Jan 7, 2017
    #4
  5. Looee
    AnalogKid
    Jun 10, 2015
    2,121
    595
    Ohio - GMT-5
    Actually, I think my response was very helpful. It was carefully crafted to encapsulate all of the technical requirement in post #1.
    ak
    #5
  6. Looee
    Alec_t
    Jul 7, 2015
    2,300
    594
    Wales
    What opamp are you using to drive a 120V power line?
    Alec_t, Jan 7, 2017
    #6
  7. Looee
    tedstruk
    Jan 7, 2012
    447
    7
    Toledo Washington
    I thought all op amps were connected in parallel...
    tedstruk, Jan 8, 2017
    #7
  8. Looee
    AnalogKid
    Jun 10, 2015
    2,121
    595
    Ohio - GMT-5
    Is that stereotyping?
    AnalogKid, Jan 8, 2017
    #8
  9. Looee
    davenn Moderator
    12,596
    1,558
    Sydney, Australia
    more bad/incorrect advice
    davenn, Jan 8, 2017
    #9
  10. Looee
    Audioguru
    Sep 24, 2016
    1,996
    461
    In the United States your circuit is feeding the entire country's electricity grid. You need the power from millions of paralleled opamps to drive it. If you add a series inductor to isolate your electricity line at each end then you will need the power only from hundreds of opamps. Is your receiver sensitive?
    How do you prevent the 120VAC from destroying the low voltage outputs of the opamps?
    Audioguru, Jan 8, 2017
    #10
  11. Looee
    23,923
    2,309
    This is typically and commonly achieved by capacitively coupling your signal to the mains. The inductance of the mains is quite high at higher frequencies due to the transformers from which it is fed.
    I'm not sure if the exact requirements for driving these signals, but a quick Google should find them for you.
    Edit: search for "power line communication" (PLC), "Broadband over power line" (BPL), "Ethernet over power", and "carrier current signalling".
    (*steve*), Jan 8, 2017
    #11
  12. Looee
    7,056
    1,463
    Worcester, MA
    I have seen capacitors and transformers used for coupling a signal to mains.
    BobK, Jan 8, 2017
    #12
  13. Looee
    AnalogKid
    Jun 10, 2015
    2,121
    595
    Ohio - GMT-5
    The classic National Semiconductor app note circuit used a strange semi-resonant transformer that was available through distribution for a while. Both AM and FM "wireless" intercoms used some variation of it.
    ak
    #13
    1. Advertisements
