C
cfjwang
I have an old Cutler Hammer panel . I can add more circuits by using the
"duplex" circuit breakers. But the neutral and ground buss bar areas are
very crowded already. The panel has two metal bars shorted together and the
previous owner use the two bars interchangeably for both ground and neutral.
One solution is to add a dedicated ground buss bar and connect it back to
the two original ground/neutral bars (I plan to use the original two bars
for neutral only).
1. Is this the right thing to do?
2. Does it require a permit?
3. Can I just find a mounting bracket and just bolt the assembly inside
the control panel?
4. What other things do I need to pay attention to?
Thanks for the help!
Jerry
for neutral only).
the control panel?
Jerry
