How man y watt FPL light tube should I use?
Discussion in 'Lighting' started by Abhisheka, Jan 21, 2013.
  1. Abhisheka
    Abhisheka Guest
    Hi
    I am non from electrical background.
    At my place there is box say don't know what to call this say light box .
    It has choke fixed of 40 watt as we found in old age tube light plates.
    There is place to attach FPL pattern bulb/tube.
    I am not sure how many watt FPL/Tube should I use.
    Is there any problem I should use 11 watt FPL ?
    Whats the logging behind choosing right watt of bulb?
    #1
    1. Advertisements
  2. The tube has to match the ballast, or you will likely be
    running it at the wrong power, which might cause the tube
    or ballast to overheat, and/or short tube life (or not work
    at all).
    Andrew Gabriel, Jan 22, 2013
    #2
    1. Advertisements
  3. Abhisheka
    Abhisheka Guest
    Thanks for reply Andrew.
    So I have to use 40Watt FPL tube.
    Abhisheka, Jan 25, 2013
    #3
    1. Advertisements
