How long bright flashing LED last on AA cells?
Jaxx
Very approximetely how long would a single super-bright red flashing LED
last?
The power source would be one (or more but how many?) rechargeable NiMH
AA cells each with a capacity of 1000 mAh?
W
William P.N. Smith
last?
Well, the venerable LM3903 gets a couple of years out of an alkaline D
cell, and IIRC 6 months out of an alkaline AA. Since your voltage is
lower and your amp-hours are about half, and self-discharge is much
higher in rechargables than primary cells, probably 3 months.
P
Palindr☻me
last?
If you make your own flasher electronics, using inverter techniques so
that the flasher will continue to operate until the battery is almost
totally discharged :- up to several years.
A suitable circuit will work for many days, if not weeks, from cells
normally considered "spent".
R
Roger Hamlett
last?
Key problem here is the words 'rechargeable NiMh'. The _self discharge_ of
many rechargeable batteries, exceeds the current consumption that the
circuit could be made to have (depends how fast you flash the light). Many
batteries of this sort, especially the high power designs, have poor
performance in this regard. This is why non rechargeable batteries are
often preferred in units designed to run for a long time.
Best Wishes
V
Victor Roberts
last?
I'm surprised that so many people have an answer when you
have not told us how much current this LED will draw in your
application. The life of your battery depends on the
average amount of current it must provide. While we can
guess at the duty cycle for pulse operation, the LED current
that is needed can vary by a factor of 10, 100 or even 1000
for different applications. We cannot use the term "super
bright" to determine the operating current since is not an
industry standard definition. One manufacturer's "super
bright" LED may be rated for a very different current than
"super bright" LEDs made by another company. In addition,
many of the examples given for flashing LED systems that
have very long battery life obviously run the LEDs at far
less than rated current.
Just to give one example, if you used a Lumileds Luxeon
Star, your 1000 mAh battery will last for less than 3 hours
of continuous operation, less than 12 hours if the LED is
operated at 50% duty cycle and less than 24 hours if the LED
is operated at 25% duty cycle. If, on the other hand, you
used a 20 mA LED then your 1000 mAh cell will last about 200
hours IF you run the LED at 20 mA when it is on and it is
operated at a 25% duty cycle.
To get the long operating times mentioned in previous
messages obviously requires that the LED current be far
lower than 20 mA, which I would not call "super bright".
Vic Roberts
http://www.RobertsResearchInc.com
To reply via e-mail:
replace xxx with vdr in the Reply to: address
or use e-mail address listed at the Web site.
This information is provided for educational purposes only.
It may not be used in any publication or posted on any Web
site without written permission.
P
Palindr☻me
No. As you start by saying, operating time does depend on the average
current (and self-discharge rates). A long operating time can be
achieved with the LED current at 20mA or more when on, if the duty cycle
is low enough. A very low duty cycle is pretty common for a flashing LED
running from a battery supply.
Making a small inductor the load of a multivibrator oscillator, with the
LED in parallel with it, can produce a train of "super bright" flashes
even from a supply of <1v.
C
Clive Mitchell
Adam said:
AAA alkaline used in Pink Floyd`s Pulse could last a couple of years:
http://www.aume22.dsl.pipex.com/floyd/pinkfloyd.html
Looks like the humble LM3909 which is obsolete now. Quite an expensive
assembly for an album novelty.
Ironically it's cheaper to use a microprocessor now. You set the
watchdog to wake the processor up after a specific delay and the program
consists of turning the LED on, running a short blink time delay,
turning the LED off and going to sleep. The watchdog resets the
processor and it starts again. You can set the LED current (resistor) on
time and off time as desired.
Does require more than one battery though.
V
Victor Roberts
What duty cycle would you use?
Vic Roberts
A
Adam Aglionby
Used to have one lying around AFAIR it was a LM3909, on a short pulse
long break cycle.
Build quality was nice for a CD box, but novelty sleeves are much rarer
nowadays with smaller artwork space, lensatic 3D Raven LP by the
Stranglers was another nice one. Soft rock group made a shaped disc in
shape of Africa the continent, problem was Cape Horn jammed on some
turntables tone arm pivot.
Adam
S
Spehro Pefhany
There was a Logictech mouse sold some years ago with a flashing LED in
the box. It used two very nice AA Ultra Duracells in conjuction with a
little COB assembly-- a CMOS ASIC under the epoxy. Just three
additional parts- the LED itself and two resistors to set frequency
and LED current. Duty cycle fixed. Output was an NMOS open-drain with
about 18 ohms Rds(on) typical.
BTW, despite the voltage doubling drive circuit, the LM3909 was not
capable of driving many modern non-red LEDs from a single 1.5V cell
because of the low output voltage.
For hobbyists anyway.
You set the
I don't know of any flash parts that have an on-chip voltage doubler,
but there are plenty of mask-programmed micros and ASICs. I'd love to
hear of any mask programmed parts..
Best regards,
Spehro Pefhany
P
Palindr☻me
It depends on the application :)
For example:
For a torch with a super bright LED running off a single cell, I would
probably have an adjustable duty cycle from 5 - 50%. That would give
adjustable brightness (and run-time).
For a "walker on road setting", one 10 mSec flash, 3 times a second.
Cyclically varying the repetition rate is more likely to get it seen.
For a "power on" indicator where power is limited, one 5mSec flash every
10 secs is a starting point.
V
Victor Roberts
[snip]
For example:
That's quite a large duty cycle range. 50% to 0.05% or a
range of 1000. Which do you think the OP was referring to
when he asked about his battery life?
Vic Roberts
P
Palindr☻me
Victor said:
[snip]
For example:
If he had to ask the question posed, I shouldn't imagine that he knew
either.
All that was clear was that he wanted a bright LED to flash and wanted
to power it from, ideally one, but if necessary more, AA NiMH cells -
and was concerned how long it would keep flashing. The logical inference
was that he wanted it to flash for as long as possible.
He know knows that, if he wants, he can keep the LED flashing for months
of a single AA NiMH cell...which I think rather answers his question.
Perhaps. ;)
C
Clive Mitchell
inference was that he wanted it to flash for as long as possible.
months of a single AA NiMH cell...which I think rather answers his
question. Perhaps. ;)
I'll have a guess at the application.....
They probably wanted to add a flashing LED to a fake camera that could
run for a long time on a battery.
In reality, a short duty cycle blinking LED on a camera immediately says
FAKE! :)
L
Lostgallifreyan
FAKE! :)
If that's true, it won't deter a thief. Bear with me here, the logic gets
interesting.. >:)
If it won't deter a thief, it's very important that cameras with flashing LED's
on them actually contain lenses and working circuits to gather video evidence
of the events that they might seem to encourage. Therefore it makes sense to
always have something real in there, so in practise, you'd be wrong. :)
In the end it comes down to two types of criminal (occupying various points on
a single line continuum actually). Smart, and dumb. The smart ones will think
this logic through and know that there is no easy guide, a small stub sticking
out the top might be a radio aerial that sends a keep-alive pulse that would
set an alarm off if it was sabotaged to prevent transmission, so a lack of
wires would deter a smart criminal, but not a very stupid one.
So, the LED makes sense, it will deter the smart ones, who will usually have
easier ways to make a dishonest living, and there's not much you can do about
the dumb ones, they're hard to predict. They're usually opportunists though, so
if everything else looks like a deterrent too, they'll leave well alone. I've
had an empty bell-box on a wall over my window for 20 years, and it works, I've
even overheard discussions outside once, and the general tenor was one of
nervous defiance, but the nervousness won out.
If it looks like a duck, how long do you wait to see if it quacks like a duck?
The longer you wait, the more uncertain you get, and uncertainty undermines
resolve, especially of criminals.
And that, ladies and gentlemen, ends my self-amusing rant for the day. >:)
E
ehsjr
application.
Did you read the answers? Which one(s) did you find
surprising in view of the fact that the op did not
tell us the current requirement?
I saw only 1 answer that would have required knowing
the op's current requirement to support the respondent's
conclusion. So I wonder what I am missing?
Ed
V
Victor Roberts
Yes.
All of them - because the OP did not tell us the current.
The answers that didn't require knowing the OP's current
requirements were probably correct for the assumptions made
by the responder, but not specific to the OP's question.
Vic Roberts
L
Lostgallifreyan
Doesn't matter though, there are two ways to go, either demand exact specs from
someone who might not have a clear idea yet, or post a response based on your
own carefully judged assumption. The latter is usually easier that waiting and
second-guessing your response before you've made one, and it gives the OP
something to think about. If the result is confusion and an apparent grasping
at each offered straw in turn, then it is probably wise to demand some kind of
focussed assessment of the original situation. At least this way the OP is not
considered stupid until proven intelligent. :)
My own thoughts on the topic are: you can have a 'super-bright' LED and long
life, but a few things should be managed to do it. Use a lithium battery
preferably, then alkaline, and avoid Nimh types. Use a power converter to
efficiently make use of the entire battery charge. Use a narrow viewing angle
on the LED, so that it projects strongly for only a limited point of view. Use
a clear LED not a coloured plastic. Use a short duty cycle, less than 1% and
pulse length no longer than 50 milliseconds even when the flash period is
longer than 5 seconds, with that period never being longer than 10 seconds
unless you're really going to be staring at that LED for 30 seconds or more
regardless of what it might be doing. These are not hard and fast rules. :)
Lastly, consider a low power laser diode, UNLENSED. These are eye safe at
distances beyond a few inches, (take care NOT to use a microlensed version
though) as they diverge strongly. Their output is highly monochromatic,
specular, very eye-catching, and their conversion of electricity to light is
second to none, so they can make ideal beacons. They're much harder to use
though, easily damaged, and initial power requirements are higher. Also, while
you can make an LED stand much higher currents than their nominal rating, often
tenfold increase, with a laser diode, the pulse rating for a CW diode is
usually less than twofold higher.
D
Don Klipstein
interesting.. >:)
LEDs on them actually contain lenses and working circuits to gather video
evidence of the events that they might seem to encourage. Therefore it
makes sense to always have something real in there, so in practise, you'd
be wrong. :)
I have some ideas...
1. If this is to be used in the home, power the LED from a wall wart.
And maybe power the LED through two steering diodes coming together - one
from the wall wart and the other from a backup battery.
For that matter, get the cheapest actual security camera you can find
from a hobbyist/surplus catalog - even if it's incompatible with anything
practical.
Or further for that matter, find some little professional looking case
and fit some cheap webcam into it and you have a fake security camera that
may actually be made to work in some way as a real one! Put a red LED on
the case...
2. I have an idea for the red LED - make it glow continuously like those
on real cameras that have LEDs do. Get a GaAlAsP red LED, peak
wavelength 660 nm, 3000 mcd (with a usual beam width of 15 degrees but
sometimes claimed more), such as Radio Shack 276-307. Red LEDs of
same/similar chemistry and efficiency are Agilent HLMP-8103 and HLMP-C124.
Get some fine sandpaper and sand down the tip by about a millimeter,
then restore the "bullet" shape but about a millimeter shorter and with
the tip very slightly more blunt, then get some really fine sandpaper and
get the LED good and evenly frosted. After that, you have a super high
efficiency diffused wide angle red LED that works well and reliably at 1
milliamp, and may be bright enough at half a milliamp. It will glow with
a color close enough to that of lower efficiency red LEDs.
If you really want to go all out, get an InGaN green LED (nominal
wavelength usually 525 to 530 nm) of the common 5 mm "bullet" style and
give it the sandpaper treatment described above. Then give it half a
milliamp or maybe a quarter of a milliamp. Most Nichia 5 mm green ones
and those trying to compete with them (ETG, and others) should at half a
milliamp have a brightness that I consider "fully that of a usual green
LED indicator light". Furthermore, the wavelength of these tends to shift
a little inversely with current, and at half a milliamp the color is
likely to be about that of LEDs with nominal wavelength in the 550's nm,
maybe close to 560 - a yellowish shade of green likely to look enough like
a usual 565 nm green LED indicator lamp to look like a usual indicator LED
to most criminals.
A pack of (4) AA alkaline cells with a 6.8K resistor should power such a
green LED reasonably well 24/7 for at least half a year.
If you want an LED to falsely indicate presence of a security system in
an automobile, don't worry about conserving every milliamp since the
battery has self-discharge in the 10's of milliamps. You can afford a few
milliamps to protect a car.
- Don Klipstein ([email protected])
