How is it possible to control the output signal amplitude for op-amp
Toroid
Oct 9, 2017
3
Oct 9, 2017
3
How is it possible to control the output signal amplitude (Vout) for any particular waveform generator so
as to satisfy a particular designing criterion ?
I am referring to waveform generators using op amp 741 like
->ex.square wave generator using astable multivibrator
->the output voltage jumps from +Vsat to -Vsat how can i make it to something else that I want.
Harald Kapp
13,738
13,738
The gain of an opamp circuit is usually controlled using resistors and a feedback loop.
Show us a diagram of your circuit for further duscussion.
Toroid
Oct 9, 2017
3
Oct 9, 2017
3
The output voltage jumps from +Vsat to -Vsat as shown in the waveform
Harald Kapp
13,738
13,738
It is supposed to do that, that is the operating principle of this oscillator. If you want another amplitude, you need to scale down the output by e.g. a resistive divider.
Toroid
Oct 9, 2017
3
Oct 9, 2017
3
Can we decrease the supply voltage?
ie. +Vcc and -Vee (since saturation voltage depends on the supply voltage)
Harald Kapp
13,738
13,738
Yes you can. As long as the supply voltage meets the operating range of the opamp.
