How is battery capacity calculated ?
Discussion in 'Electronic Design' started by dakupoto@gmail.com, Jan 10, 2014.
  1. Guest
    To all the electronics gurus on this newsgroup -
    how is battery capacity decided - for example
    if I buy a 6 Volt 5AH sealed lead acid battery,
    how did the manufacturer come up with the number
    5AH ?
    , Jan 10, 2014
    #1
    1. Advertisements
  2. Phil Allison Guest
    ** You could easily Google that question you know.
    FYI:
    For SLA batteries, makers use the "20 hour rate" for the published AH
    figure.
    So for 5AH, the battery is discharged at 250mA for 20 hours for a final
    terminal voltage not less than 1.7V per cell.
    http://www.steveduncan.net/assets/images/mfg_curves.jpg
    ..... Phil
    Phil Allison, Jan 10, 2014
    #2
    1. Advertisements
  3. Artem Guest
    Who is the manufacturer? Some manufacturers provide discharge/charge curves. Bear in mind that the lead-acid batteries rapidly degrade at 100% charge / discharge cycle.
    Artem, Jan 10, 2014
    #3
    1. Advertisements
