Jon D
I am in the UK.
I have a hi-fi cassette player and I feed the outputs to the line-in
on the motherboard of my PC.
I get a horrible hum on the recording I make on the PC. The
recordings are of phone conversations so the overall quality of what
I am recording is not great but the hum is still very distracting.
(1) I am told that an audio isolating transformer should work.
However I have learnt that basic transformers with only a small metal
core are prone to picking up hum. So I figure any such isolation
will remove noises I don't have but will be liable to getting the hum
I want to get rid of!
(2) I believe another way of reducing hum is to take off the earth
from either the source or destination equipment. However the
cassette player does not have an earth. Would it help to take the
earth off the PC?
(3) Or should I actually add an earth to the cassette recoder? -->
Maybe take the mains earth from the mains socket and connect it to
the outer of the signal lead? Or to the brushed aluminium case of
the cassette recorder?
I get this hum if I take the signal from the line-out or the earphone
sockets of the tape player. Changing the input socket on the PC to
the mic socket does not help. The lead is not damaged because I can
use that lead to replay from a battery-powered dictation machine into
the PC without any hum.
earth off the PC?
