How do I wire a BMP085 Barometric Pressure Sensor?
Discussion in 'Sensors and Actuators' started by Vagulus, May 15, 2018.
  1. Vagulus
    Vagulus
    May 6, 2018
    15
    Perth Western Australia
    I would like to include a BMP085 sensor in a weather station project build around an Arduino Pro Mini breakout. Sadly, the link from Core Electronics leads to a datasheet for the Chip itself, not the breakout. Can someone please tell me how to wire this little beastie into a Pro Mini?
    #1
    1. Advertisements
  2. Vagulus
    7,067
    1,466
    Worcester, MA
    A breakout board typically just brings out the pins in a more hobbyist friendly form (like DIL). The datasheet should tell you all you need.
    BobK, May 15, 2018
    #2
    1. Advertisements
  3. Vagulus
    Bluejets
    Oct 5, 2014
    2,442
    477
    First bit of the link says" i2c"
    Bluejets, May 15, 2018
    #3
  4. Vagulus
    davenn Moderator
    12,597
    1,560
    Sydney, Australia
    As @BobK said ... all the info is in the datasheet ... the chip pins are identified. There 7 out of the 8 pins are used (pin 5 in not connected)
    you can easily trace those IC pins to the header pin connector and problem of pin ID is solved
    as far as connecting to the Arduino Pro Mini goes, that isn't my field .... does the Arduino Pro Mini handle an I2C Bus ?
    davenn, May 15, 2018
    #4
  5. Vagulus
    Vagulus
    May 6, 2018
    15
    I am an extreme beginner in this sort of stuff so, Bluejets I do not appreciate the significance of i2c. What's that all about?
    I have to ask BobK and davenn whether we are reading the same thing (see attached file). I don't see anything that identifies 7 out of 8 pins. Maybe that's just me being an electronic dyslexic, but I don't see anything. Can you be a little more explicit?
    #5
  6. Vagulus
    bushtech
    Sep 13, 2016
    678
    109
    Vaalkopdam North West
    Page 18 of your attached file gives the pinouts
    bushtech, May 15, 2018
    #6
    davenn likes this.
  7. Vagulus
    Vagulus
    May 6, 2018
    15
    Ooooh! Silly me. I'll have to learn to read further down the document. :oops:
    #7
  8. Vagulus
    bushtech
    Sep 13, 2016
    678
    109
    Getting into the habit of reading the Table of Contents (page 4) is usually a great start
    #8
  9. Vagulus
    Vagulus
    May 6, 2018
    15
    I looked up Wikipedia in i2c and it is way too sophisticated for me to grasp at this stage. However, I get the impression that the Auruino Pro Mini is not i2c-capable. It does not have pins designated SCL or SDA.
    Is that right?
    #9
  10. Vagulus
    Vagulus
    May 6, 2018
    15
    I figured out why I didn't get that far in the documentation. I had realized that the documentation was for the IC itself, not the breakout I was intending to use (BMP085 sensor) so the pinouts on page 18 weren't what I was looking for. :rolleyes:
    No harm done. I'm using a different breakout now - one I can get some documentation for. :)
    #10
  11. Vagulus
    Bluejets
    Oct 5, 2014
    2,442
    477
    You will quickly learn that in electronics there are no shortcuts if you want to educate yourself.
    Promini pinout attached.
    A4 .....SDA
    A5 ..... SCL
    #11
    hevans1944 likes this.
  12. Vagulus
    Vagulus
    May 6, 2018
    15
    That's true in other fields than electronics ;)
    [QUOTE="Bluejets, post: 1766426, member: 37203"
    A4 .....SDA
    A5 ..... SCL[/QUOTE]
    Well ... I've seen a pile of Pro Mini diagrams but never seen that info.
    #12
  13. Vagulus
    kellys_eye
    Jun 25, 2010
    3,122
    829
    West Coast, Scotland
    Devices that use I2C and the Arduino usually have 'sketches' to accompany them - these are short programs that you can embed into your own application and modify to get the data you want.
    kellys_eye, May 15, 2018
    #13
  14. Vagulus
    hevans1944 Hop - AC8NS
    Jun 21, 2012
    3,681
    1,771
    Venice, Florida, USA
    hevans1944, May 15, 2018
    #14
    1. Advertisements
