How do constant current loads work and how to make one
Discussion in 'General Electronics Discussion' started by Alexsieg, Sep 30, 2016.
  1. Alexsieg
    Alexsieg
    Sep 30, 2016
    8
    Hi, I'm not the best at understanding electronics, how does a constant current load work and how can i make one, and what makes them have limits before they get fried?
    #1
    1. Advertisements
  2. Alexsieg
    AnalogKid
    Jun 10, 2015
    2,074
    588
    Ohio - GMT-5
    There are several ways to make a constant current circuit, and searching for the term 'constant current schematic' will return many schematics. One way is to monitor the voltage across a resistor, and use an opamp to automatically adjust the conduction of a transistor such that the voltage is a constant value. A constant voltage across a fixed resistance means there is a constant current through the resistance.
    Depending on the voltage across the resistance vs. the voltage across the transistor, you can distribute the power dissipation between the two components. After that it's an issue of thermal management. If the parts exceed their rated power dissipation, they burn up. If they exceed their rated operating temperature, they burn up. Heatsinks help, but do not guarantee survival.
    ak
    AnalogKid, Sep 30, 2016
    #2
    1. Advertisements
  3. Alexsieg
    Alexsieg
    Sep 30, 2016
    8
    Im not really sure how all that works, all I've really made with electronics is a power bank from a few laptop batteries and just mess around with stuff.
    #3
  4. Alexsieg
    hevans1944 Hop - AC8NS
    Jun 21, 2012
    3,623
    1,751
    Venice, Florida, USA
    So, why do you want a "constant current" circuit? What kind of load do you want to attach to it? Do you use any meters or math when you mess around with stuff?:rolleyes: Please tell us what you are trying to DO.
    hevans1944, Sep 30, 2016
    #4
    Arouse1973 and Harald Kapp like this.
  5. Alexsieg
    Ratch
    Mar 10, 2013
    940
    277
    If you cannot understand the explanation of how to do it, and have minimum electronic construction skills, how do you expect to achieve the goal of building what you want. Perhaps a study of elementary electrical theory knowledge and hardware basics is in order first.
    Ratch
    Ratch, Sep 30, 2016
    #5
    Arouse1973 and hevans1944 like this.
  6. Alexsieg
    Miguel Lopez
    Jan 25, 2012
    234
    52
    Mayabeque, Cuba
    Miguel Lopez, Sep 30, 2016
    #6
    hevans1944 and (*steve*) like this.
  7. Alexsieg
    Alexsieg
    Sep 30, 2016
    8
    I just want to make a constant current load instead of buying one, and how powerful could i make one without it being ridiculously expensive.
    Alexsieg, Oct 1, 2016
    #7
  8. Alexsieg
    Alexsieg
    Sep 30, 2016
    8
    I know most of the basics of electronics i just don't know how to make circuits that to crazy things.
    #8
  9. Alexsieg
    duke37
    Jan 9, 2011
    4,874
    632
    Derbyshire. UK
    At a rough guess you should be able to make a 1000V 1A supply for under $10000. A bargain.:)
    duke37, Oct 1, 2016
    #9
  10. Alexsieg
    23,811
    2,270
    Are you wanting to produce a load for testing batteries?
    If so, what is the maximum and minimum voltage you would want applied to it, and the maximum and minimum current you'd like to set it to sink?
    (*steve*), Oct 1, 2016
    #10
  11. Alexsieg
    Jun 21, 2012
    3,623
    1,751
    I bet I could do something for a dollar. My specs, of course.
    hevans1944, Oct 2, 2016
    #11
  12. Alexsieg
    Herschel Peeler
    Feb 21, 2016
    400
    65
    Las Vegas
    More specifics, please. Vague assistance is all we can give for vague requests.
    What schematics have you found so far that might be close to your needs?
    Herschel Peeler, Oct 2, 2016
    #12
  13. Alexsieg
    Herschel Peeler
    Feb 21, 2016
    400
    65
    Las Vegas
    Something like this? Basically you use a transistor as the load. You turn it on and into conduction just enough to be the resistance you need. Instead of driving the load it is the load.
    #13
  14. Alexsieg
    Miguel Lopez
    Jan 25, 2012
    234
    52
    Mayabeque, Cuba
    I can do it cheaper. Of course, my own specs :D
    Miguel Lopez, Oct 3, 2016
    #14
    (*steve*) likes this.
  15. Alexsieg
    Jun 21, 2012
    3,623
    1,751
    Yeah, Miguel, no way I can compete with off-shore labor.:( I bet someone in Asia can make this for nothing, and make a profit on the volume sold.:p
    hevans1944, Oct 3, 2016
    #15
  16. Alexsieg
    Alexsieg
    Sep 30, 2016
    8
    I only need it to go up to 25v and around 5 amps.
    Alexsieg, Oct 9, 2016
    #16
  17. Alexsieg
    23,811
    2,270
    Ok, so they are the maximum ratings, what is the minimum voltage across the input that should allow it to operate at maximum current? What are the typical current you'd want it to operate at -- especially the lowest?
    (*steve*), Oct 9, 2016
    #17
  18. Alexsieg
    Alexsieg
    Sep 30, 2016
    8
    The lowest voltage i would want it to run would be 3v, and a external power supply to keep it running of course.
    #18
  19. Alexsieg
    23,811
    2,270
    And the smallest current? Would you want to be able to easily and accurately set it for 1mA, or would a couple of hundred mA be practically the smallest current you'd require?
    #19
  20. Alexsieg
    Alexsieg
    Sep 30, 2016
    8
    The lowest i think should be 200ma if not then 400ma
    #20
    1. Advertisements
