billybobbonnet
- May 1, 2017
- 1
- Joined
- May 1, 2017
- Messages
- 1
Hello,
I am a newbie (/noob) in electronics, practicing on occasions. I just had an idea for a beach game and I would like to know if my assumptions about the electronics are right.
I want to make a foam piece with several wires on the surface. The role of the wire iis to trigger a led/sound every time they come in contact with human skin., as opposed to another foam block with the same setup or sand, (or sea?). Feel free to guess what I have in mind ^^.
I assume that with a low voltage on the naked wires I could detect when tension drops/resistance change/ (?).
I intended to give it a try with an arduino and some cheap pieces but I need guidance about where to look/investigate first.
Thank you
Thank you
