Joerg
Jasen said:AIUI The "doof-doof car" builders just wire them in series or parallell.
Air looses 1/8 of it's volume if compressed 2PSI you could add a
passive comonent to the driver on the high pressure end to compensate
for the shorter throw and therefore lower innertial load.
But in my opinion 12% is not a large mismatch, simple is probably
better.
IIUC the series assembly of such speaker still won't solve the problem
that the front speaker has to do full excursion for the require pressure
of 4psi. So its surround would still fail after some time, like it did
on mine. They had enough power, they just could not stand the pressure.
