O
ocular
Looking at 12volt power supply for my Honda EU10i generator
http://www.grahams.com.au/Grahams/index.cfm?ID=184&ProductView=421
It only puts out 8 amps (non regulated)
What if I plugged in a Powertech Switchmode 3-15volts - 40 A Unit.
http://www.rpc.com.au/products/batteries/switchmode/switchmode.html
Would the switchmode power supply function normally ( should do as the
Honda output is sine wave "and will run sensitive equipment:?)
Will the Honda generator have enough power (1000 watts) for the
switchmode supply (40x15 + 10%) (assume 90% efficiency) = 700watts.
I have heard that at least with the industrial 240 volt generators -
switchmode power supplies may not work and that with transformer type
power supplies the power rating of the generator needs to be much more
than the power rating of the transformer type power supply. Does this
apply to switch mode power supplies and generators such as the Honda
10EU1?
10EU1?
