Home made PCBs
C
Charles Jean
What's the best way to make little ones from big ones? I would like a
method that takes a small kerf and produces a straight line. For
one-at-a-time boards. One that a klutz can handle.
TIA
Charlie
P
Pooh Bear
Sorry mate. I don't understand your line of banter.
Graham
I have used a straightedge and a tool that is used to scribe and cut
plastic laminate and linoleum...it has a carbide cutter on a steel
blade and after lining up the straightedge I give the cutter a few
pulls to make a groove...then remove the straightedge and keep pulling
the cutter thru...turning the board around every few strokes to make it
even.
This produces a clean but beveled edge which I flatten up by rubbing
the cut edge on a file.
scroll down page to see one
http://www.tapeease.com/LamTls.htm
JazzMan
TIA
Charlie
I use aviation style tin snips, the kind with the compound
action. Use the straight cut.
JazzMan
Please reply to jsavage"at"airmail.net.
Curse those darned bulk e-mailers!
"Rats and roaches live by competition under the laws of
supply and demand. It is the privilege of human beings to
live under the laws of justice and mercy." - Wendell Berry
E
ehsjr
TIA
Charlie
Best? Dunno. Easiest? A paper trimmer. Item # 818674 at
http://www.staples.com/
Jeff Dege
I score both sides, with a screwdriver, then stick it in a vice and snap
it off.
Jasen Betts
the "best way" is to start with them the right size,
assuming a typical garage/basement workshop...
use a steel ruler and a sharp knife (box cutter etc)
mark the ends of the cut with notches or holes
clamp the ruler to the PCB (use a vice, g-clamps, Vice-grips(tm) etc)
and make several passes with the knife,
repeat on the other side.
repuat until cut all the way though or go about 1/4 way and snap it off.
smooth the edge on a file or other abrasive surface,
R
Rich Grise, but drunk
JazzMan
I once, very long ago, in a galaxy far away, made a 6-up of a 2.5"dia.
round circuit, double-sided, on .031 fiberglass. (copper clad, both sides,
I etched it in FeCl3, drilled it with a little Dremel drill press, and
fudged on the vias).
I don't remember exactly what tool I used to trim them to size, but just
that fact that I don't remember indicates to me that it must have been
trivially easy. Like, Mom's sewing shears or something.
But this was .031" stock - I guess for .062, if I was really persnickety,
I'd press a die grinder into service as a little router.
Getting them apart in the first place, well, I'd say, shear them, score
and snap them, saw cut them, whatever works. It's pretty much a matter of
taste and getting your hands dirty. ;-)
Cheers!
Rich
