D
Darmok
I finally had my old fuse box replaced with a Cutler-Hammer circuit
breaker box last year. It has a 'disconnect' in it, to isolate me
from the local power company. I had this added, as my intention was
to be able to 'back feed' power to the box via a side door outdoor
receptacle. Its a standard 12 circuit box, 6 to a side. On the left
side is a 70 amp dbl breaker which serves as the disconnect. This
side also has a 20 amp dbl. (220vac) breaker for the central A/C.
There are 2 open circuits on the left side. On the right side are 6
20 amp breakers for the rest of the house, various rooms.
Now, the way I figured it, when the power goes out (like it does about
every time a squirrel farts around here), all I'd have to do is
disconnect from the power company, flip the A/C breaker (for safety,
and turn it off at the thermostat), and then plug my generator into
the outdoor receptacle via a dbl. male extension (using very high
quality 12-3 Polar/Solar GE cable ... about 3/4" diameter).
Well, I had a chance to try this out a couple days ago, when power was
out for 4 hours (we had a thunderstorm ... not a bad one ... we just
lose power a LOT). I plugged in the generator after it leveled out,
and was greeted with lights when I entered the house. HOWEVER, there
were 3 rooms where there was no power. 3 rooms had power. When I
went to the circuit box, I pulled the cover and, using my DMM, I found
that every other circuit breaker had no AC on it: #1 hot; #2 dead; #3
hot; #4 dead; #5 hot; #6 dead. I sort of figured that the entire
right side of the box would be powered up, but maybe there's some kind
of alternating pattern to "balance the load". That's the only thing I
can think of. Can anyone shed light on why I have power to only half
the circuits? I'm a professional electronic technical specialist, and
work with SMT/BGA boards every day ... but I'm NOT an electrician, so
I'm out of my area of expertise.
TV's and computer, radios and lights all worked fine. A ceiling fan
in the living room was making a weird noise, and it finally stopped
circulating after a bit. I thought it died, for some strange reason,
however, when the power came back on, and I once again connected to
the power company, the ceiling fan worked fine. Don't understand that
one at all. Do all motored items not work with generator power? Am I
wrong to think that my refrigerator will work properly with generator
power? (the kitchen was one of the rooms that didn't power up)
With the disconnect turned off, and the A/C breaker OFF, would it be
safe to jumper something to get power to the unpowered circuits?
Thanks for any help.
