F
[email protected]
What's the highest energy cap available and it's source?
The most cost effective?
where energy is the product C * V^2
i agree with youWhat's the highest energy cap available and it's source?
1/2 C * V^2 in fact.
Storing energy at high voltage is best since a caps's size is determined by the
CV product wheras energy is prop to V^2.
Graham
Spehro said:I think the volume of the required dielectric is proportional to the
maximum energy stored, assuming a constant volts per mil dielectric
breakdown rating.
Best regards,
Spehro Pefhany
Surely the thickness of the dielectric would be prop to voltage ?
Hence size > CV >whilst energy > 1/2 C*V^2.
This certainly what I've found.
Graham
Yes, let's say. But capacitance is prop to 1/thickness.
Okay (parallel plates, ignore edge effects)
capacitance = e * A/t where a is the area and t is the distance
between plates and e is the permittivity.
t = k * V, where V is the maximum operating voltage and 1/k is the
dielectric breakdown voltage in volts/unit thickness
(Max) Energy = (1/2) * V^2 * e * A/t = (1/2) * V * e* A/k
we also have dielectric Volume = t * A = k * V * A
so (Max) Energy/Volume = e/(2*k^2), a constant dependent only on
dielectric characteristics
I also think this makes sense intuitively.
Best regards,
Spehro Pefhany
Eeyore said:1/2 C * V^2 in fact.
Paul said:Maxwell has BCAP1200-E270 which is 1200 farads at 2.7 VDC, for about $45.40
in quantity of 1 to 99. That's 4374 joules. A bank of 27 in series will
provide 33 farads at 72 VDC, which is enough energy to absorb (or supply)
13 kW for 5 seconds (for EV acceleration and braking) at a cost of $1226.
Still not a replacement for batteries, but perfect for high current surges.
These ultracaps (BoostCaps) have an ESR of only 0.8 uOhms and peak current
of 3750 amps. They are about 3" long and 2.5" dia, and weigh about 3/4 lb.
I received this quote recently.
Check www.maxwell.com for more info. They have 650 to 2600 farads in this
series.
Paul
As a minor nit ... the 1/2 is necessary only to scale the product into
joules units, the base equation is the fundamental equation for
capacitance and voltage representing energy.
series.
I sent the Maxwell sales link a request for price and availabilty in
hundreds a little over a month ago, and never got a response. Did a
distributor respond with that quote?
I've since been looking at surplus high voltage caps in the fractional
farad range that are also kilojoule, but are about the same cost and
volume. The only advantage is that they can be connected in parallel,
and not have to worry about the balancing voltage divider.
The size proportional to CV is sort of true in electrolytics, but
obviously not in film caps. Only a small part of a 'lytic is the
actual dielectric, and most of it is carrier foil and
electrolyte/spacer.
John
John said:A big array of series/parallel electrolytics, like photoflash caps,
doesn't need equalizing resistors. Electrolytic leakage is nonlinear
enough to balance the voltages nicely. 'lytics don't fail suddenly
like film caps, they just start leaking more.
Jim said:Methinks the "minor nit" is your brain capacity ;-)
The 1/2 comes from Integral(C*V)dV
