James Rollins
I'm a bit confused about how to drive a mosfet as a switch when
dealing with high V_DS voltages. I have several nch mosfets with 100V+
up to about 1000V for max source to drain voltages.
I want to create a few buck converter circuits and others to test the
quality of the output but I cannot for the life of me figure out how
to drive the gates without requiring other high voltage components and
without the circuit becoming overly complicated.
If you take a simple voltage diving circuit with the nch mosfet
replacing the high-side resistor and try to drive the gate then the
source terminal is "floating" in the sense that it depends on the
load. If I tie the gate to the source through a resistor then this
solves the problem by turning off the mosfet. Unfortunately it then
causes major problems when trying to drive it. Not only that the gate
then has to discharge through that resistor plus the low-side
resistor, which here is the load, which reduces the fall time
significantly for low loads.
One can't simply use another nch HV switch to connect the first
mosfet's gate to ground because it brings the source of the first
mosfet way below spec.
The issue is driving the gate so that it is only within +-20V of the
source which can be up to several hundred voltages above ground almost
up to Vcc.
Is there something I'm missing here? I imagine using a p-ch mosfet
would be much easier yet I can't find ones with spec for my
application yet N-ch's are abundant.
up to Vcc.
