Hi all,
Application: I have a circuit which is powered from a lipo battery which needs to shutdown when the battery hits 3v for safety reasons. I am making use of an LT1763CS8 LDO voltage regulator which coincidentally has a shutdown pin that must be pulled up to function or LOW to shutdown power.
Question: What can I use to output HIGH when the battery voltage is 3.01v+ and LOW when its 3v or lower?
Solution: I was thinking perhaps a transistor to output low whenever the battery is 3v but I'm not sure how to connect it or calculate needed values.
Thanks a lot
Thanks a lot
