S
[email protected]
Hello,
I built a circuit from this link:
http://ourworld.compuserve.com/homepages/bill_bowden/page9.htm
entitled "High Current Mosfet toggle switch with debounced push
button. It worked perfectly on the breadboard. When I installed it
on a pcb board with an external switch (inside an enclosure) the
circuit now powers on active. In other words, the IR510 Mosfet has
power on the gate pin, which is not how I want it to work. Can
anybody suggest what values I might change the10k/10uF on left side of
circuit to, to resolve this?
The other issue I have is with the load. I connected a relay (k1,
24vdc coil)to the load terminals and had what I will call debounce,
where the relay doesn't always close, but bounces. It may take
several times to activate it. I put a diode across the coil and that
resolved that problem. But my final load is 120vac 11amps so I am
driving a much larger relay which we will call K2. K2 has 120vac coil
and contacts. Now when K2 is in the circuit, I get the same issue.
Can I put a diode across the ac portion of the coil to control this
spike or bounce? If I remove K2, my problem is gone.
Stan
Stan
