quantumtangles
- Dec 19, 2012
- 153
- Joined
- Dec 19, 2012
- Messages
- 153
I would like independently to control the volume output of two pairs of speakers connected to the same stereo power amplifier.
Can I interpose potentiometers between the +ve and -ve speaker cable outputs, which is to say, can I plant four pots in between the amp and the speakers whose output I want to control?
The plan is to balance volume from speakers at the far end of the room with speakers to my right and left that are closer to me. I want more volume from the speakers that are further away.
So can I use pots? If so what pots would appear suitable? Is there a circuit I can build that would make for a nice project?
The system is as follows:
Technics Stereo Power Amplifier SE-A1010
Technics Stereo Control Amplifier SU-C1010
Yamaha Model NS-500 speakers x 2
Yamaha Model NS-200 speakers x 2
Stereo power amplifier specifications:
Output power 100W+100W (4 ohms, 1kHz, 0.05%)
80W+80W (6 ohms, 20Hz - 20kHz, 0.02%)
70W+70W (8 ohms, 20Hz - 20kHz, 0.015%)
THD 0.015% (-3 dB (20Hz - 20kHz), 8ohms)
Frequency characteristic 5Hz-100kHz+0 -3 dB
Dumping factor 70 (8ohms)
SN ratio 98dB(EIAJ)
115dB(IHF'66)
Input sensitivity/impedance 1V/20kohm
Meter indicating range 0.001W-200W (8ohms)
Power source AC100V, 50Hz/60Hz
Power consumption 210W
Stereo Control Amplifier Specs
http://www.usersmanualguide.com/panasonic/stereo_control_amplifier/suc1010
NS-500 Specs:
40Hz~20kHz
1.8kHz
91dB/W/m
8Ω
60W
NS-200 Specs:
35Hz~35kHz
3kHz
90dB/2.83V/m
6Ω
100W
300W
Should I bite the bullet and get an appropriate graphic equaliser/surround sound unit?
SN ratio 98dB(EIAJ)
115dB(IHF'66)
NS-500 Specs:
40Hz~20kHz
1.8kHz
91dB/W/m
8Ω
60W
NS-200 Specs:
35Hz~35kHz
3kHz
90dB/2.83V/m
6Ω
100W
300W
