F
fatninja
Hi Guys!
Hope I can get a little help here and I'm stumped!
I've got a pulse going to a coil, Normally I use a 3w Metal film resistor to
collapse the field at a set rate and adjust the values of the resistor to
change the rate at which the field is dampened.
What I am after, is a variable resistor that can do the same job.. Is there
any type of unit that will act similar to a metal film resistor as the
resistance is increased/decreased?
It can get quite warm as the field is charged and collapsed every 30us.
Thanks for any help!
