I have a JBL PRO PREMIUM COMPUTER SPEAKER SYSTEM that I am trying to repair. It consists of two satellite speakers and a powered subwoofer.
The on/off and volume controls consists of two momentary switches on a board. To turn the speakers on, you press both buttons simultaneously. To turn the satellite speakers up, you press the right button...to turn them down, the left button.
The system still powers on, but I can no longer control the volume through the switches. I am making a guess that the switches are bad (they do crackle).
Here is a pic of the system that I found on ebay. On this auction you can also see some of the electronic specs.
The only voltage specs that I can find are on the back of the subwoofer.
AC 120V~/60Hz/175W
I found some momentary switches at radio shack that are identical in terms of form factor, but the switches are rated at 50mA @ 12V DC. Here is a link.
Would these work or do I need switches rated at 120V AC?
Let me know if you have any questions that I can answer that would enable you to better help me.
thank you
Rob
AC 120V~/60Hz/175W
thank you
Rob
