marcus_clarkus
- Jul 25, 2013
- 5
- Joined
- Jul 25, 2013
- Messages
- 5
Product: Polk Audio PSW202 powered home theatre subwoofer
Problem: Blows fuses in matter of seconds
Solution: Found component causing internal short, need advice on replacing it
burnt Audio IC amp-
I'm fairly sure that the darkened solder on the bottom of the board has not come into contact with anything it shouldn't have.
amp without aluminum cover-
Picture of everything (aluminum cover in place)-
So the little audio amp on the circuit board burned out and I need to replace it with this:
Audio IC (mouser electronics)
Question #1: I've soldered wires before, is there anything special I need to know about soldering a circuit board?
Also, the heat sink for the amp was in contact with a large, aluminum enclosure and had some thermal paste and a plastic insulator on it.
aluminum cover, note the plastic piece held in place on it with thermal paste-
Question #2: Can I clean the surfaces (as I would on a PC's CPU) and reapply thermal paste that is meant for a PC's CPU?
Thanks in advance for any answers/advice!
burnt Audio IC amp-
