Eyeball_Chambers
- Jun 2, 2014
- 1
- Joined
- Jun 2, 2014
- Messages
- 1
I'm hoping you guys can help me out. I am eliminating the tail light on a motorcycle and wiring two turn signal/brake lights like a car. The way the stock motorcycle lights currently function is one dual element bulb for tail/brake light. The turn signals use single element bulbs that are only used when the turn signal flashes. My plan is to put dual element sockets and bulbs in turn signals with red lenses. I will wire the low element to the running light wire. I am hoping to use relays on the brighter element so the turn signal can override the brake light signal on either side. I have a very basic understanding of relays, but could use help with which relays to use and how to wire them. It is a 12v system. One other question I have is when the turn signal and brake are both on, how can I allow the bright element to go dark between flashes without the brake light signal just keeping the element lit?
