Help to identify component
Discussion in 'Datasheets, Manuals and Component Identification' started by +Turbo, Jul 12, 2018.
  1. +Turbo
    +Turbo
    Jul 12, 2018
    3
    I need help identifying this component. It’s part of a Honda mirror and there are no markings or numbers on it. On the pcb there’s some Japanese letters and 3309r that’s all. I narrowed it down to this being the problem but can’t identify what this is. Please help find to replace it.
    #1
    1. Advertisements
  2. +Turbo
    davenn Moderator
    12,846
    1,632
    Sydney, Australia
    HI, Welcome :)
    It's a diode, ratings, I have no idea
    can you please show sharp well lit photos of the PCB, both sides
    davenn, Jul 12, 2018
    #2
    1. Advertisements
  3. +Turbo
    dave9
    Mar 5, 2017
    409
    90
    What function of the mirror isn't working? I can't think of a mirror circuit that would need a diode, though I do agree it looks like one.
    dave9, Jul 12, 2018
    #3
  4. +Turbo
    +Turbo
    Jul 12, 2018
    3
    After looking at it I kind of figured it was a diode but I wasn’t sure since I have very basic electronic knowledge. They are power adjusting and folding mirrors from Japan. Here is a pic you can see it has 2 other diodes and the one that I took off.
    #4
  5. +Turbo
    73's de Edd
    Aug 21, 2015
    2,349
    775
    Texas
    Sir +Turbo . . . . .
    Well then, do you minimally have . . . . . or have access to . . . . .a DVM, to be able to test that one diode and see if it is being dead shorted . . . . or being open circuit.
    As well as your photo can show, I could conceive of that being used as a directional device function if you had one more like diode to then make a total of 4 of them.
    Minimally, it might be used as back EMF inductive damping on that units brush type motor.
    Otherwise I am only seeing a green disc ceramic capacitor, one other like diode and 4 wires visible . . .plus the drive motor.
    If you want to try something.
    And duly considering that diodebeing shown to us is to be rated at a maximin current carrying capability of 1 amp and at as low of a voltage rating as the bean counters mandated on enginering.
    Find yourself a common as dirt . . . .1N4007 diode and use it in the position that you pulled that one from.
    You DO need to obey installation protool in having the BLUE banded lead of that black bead diode body's wire lead, as being in agreement of a cylindrical black body with a silver band on one end, as will be on the new 1N4007 diode.
    Then only leave power on for 5 seconds of your initial trial run to confirm motor action. Works ? . . then go for it.
    Ask us if you need info on using a DVM in testing the old diode.
    As a final step, you might collect all of the spun aside goober-luber and then re apply to the two helix gears mating / meshing surfaces.
    Thassssssit . . . .
    73's de Edd
    73's de Edd, Jul 12, 2018
    #5
  6. +Turbo
    +Turbo
    Jul 12, 2018
    3
    I will try that next week since I am extremely busy this week and let you guys know. Thanks for the help.
    +Turbo, Jul 13, 2018
    #6
    davenn likes this.
    1. Advertisements
