G
gazz
wondering if anyone can help with something thats been nugging me for a
while.
my pinball machine is supposed to have a tone board to produce the sounds
you get when hitting targets, it was built in 1976 so was one of the early
machines to use electronics in it, before that it was an electromechanical
chime unit (solenoids hitting xylophone plates)
the tone board is missing from my machine, but i have tracked down the
schematic, it's a copy from the service manual,
but it dosent show all component values, B1 and B2 are the mains ones i cant
figure out,
anyone able to have a look and maybe help me decide what those components
should be, and also if the others need changing to modern equivelents?
http://www.freewebs.com/ratsarsearcade/recel sound board.pdf if the
schematic scan,
It's a very basic circuit i assume, runs on 28 volts, triggered by a 28 volt
input on one of the 4 inputs to produce the relevent tone,
i've been told they were kinda like chimes in sound, and not the beep/boops
of bally machines of that era, but i've never heard on so dont know that for
sure,
Failing identifying the components, how hard would it be to make something
modern that would produce a nice chime like tone of a different frequancy
for each input? were talking dings and dongs here like a doorbell, but 4
different and seperate tones from a low dong to a high ding,
i'm not going to attempt this untill i have my other project sorted (the
change machine timer pulser module) just if i can identify the components i
can get them ordered same time i order the ones for the other project.
while.
figure out,
schematic scan,
sure,
