Help identifying an SMD IC
R
Ross Vumbaca
I am trying to repair a damaged motherboard (it's a special PowerPC
motherboard) and one particular component was scorched and became
impossible to identify.
I obtained a high resolution photograph of the component in it's
original state from another owner of this board.
I don't know if this component can be identified though, (certainly not
by me anyway, with my meagre experience).
I was wondering if anyone might have any tips or a clue what the part
might be...
The part is labelled "C042" and a high resolution picture of the board
is here:
(Note: 800KB)
http://members.optusnet.com.au/rossv1/board.jpg
The part is U26 on this board, approximately right in the middle of the
photo)
Thanks for any tips,
Regards,
Ross..
F
Franc Zabkar
is here:
My first thought was that it may be a supervisor IC that holds the
board in a reset state until the supply reaches a predetermined
threshold. Searching for "C042" at ...
http://www.usbid.com/search/AddPartNoLogin_action.cfm
.... brings up an Exar part.
Exar make many supervisor ICs, but I couldn't find a likely candidate
at the following URL:
http://www.exar.com/Common/Content/Product.aspx?Parent=2&ID=116&SubID=24
It is possible that "C042" is a code which identifies the threshold
voltage. Many supervisor ICs use such a marking method.
- Franc Zabkar
F
Franc Zabkar
My first thought was that it may be a supervisor IC ...
On second thoughts, I think I was wrong.
Instead I think it may be an SN74LVC1G04DBVR or SN74LVC1G04DBVT
"single inverter gate".
http://www.ti.com/lit/gpn/sn74lvc1g04
Page 2 of the datasheet states that the top side marking is "C04_",
where the last digit indicates the "assembly/test site".
- Franc Zabkar
R
Ross Vumbaca
Hi Franc,
Thanks heaps for your help, really appreciated. I wasn't able to even
find a lead..
Best regards,
Ross..
