T
Tony
I'm trying to minimize losses in a high-power power factor controller driving a
continuous conduction flyback power switch circuit (actually it's a hybrid, with
resonant attributes as well, but that doesn't affect this question). As I have a
very limited power dissipation budget, I need to optimize every part of the
project, and as the PSU necessarily comes first, that's my current target.
Problem 1: In the absence of any info to the contrary I have been interpreting
the "B" parameter in the core loss density curves (mW/cc vs frequency, with B
and temperature as parameters) as p-p flux density excursion regardless of the
mean flux density (presumably as long as the flux never approaches saturation).
I have just realized from an obscure downloaded Philips document that the "B"
parameter seems to mean half the p-p flux (good for me, since I can now use
double the flux excursion), but although not it's certainly still not clear,
there seems to be an inference that the curves only hold if the flux varies from
-B to +B, ie, the average flux is zero, and I can't use any of this data to
guess the losses when B varies between, say, +300mT and +400mT. I'm further
guessing that the curves also assume sine wave excitation? Can anyone confirm or
correct all this conjecture?
Problem 2: whatever the answer to problem 1, is there any "rule of thumb", or
mathematical approximation that might help me to estimate quantitatively the
trend in losses if not the actual losses as the mean flux changes (I can't
realistically test this, at least until after I get starting design point)?
All comments will be welcome.
Tony (remove the "_" to reply by email)
