Hello can somebody tell me please collector capacitor
Discussion in 'Electronics Homework Help' started by michael1978, Jan 15, 2018.
Thread Status:
Not open for further replies.
  1. michael1978
    michael1978
    Mar 17, 2012
    82
    Hello can somebody help with t his is c1 and R2 RC time of i dont know;-) what do the capacitor?? RC TIME.jpg
    #1
    1. Advertisements
  2. michael1978
    davenn Moderator
    12,369
    1,494
    Sydney, Australia
    this looks like a homework/study style question
    I have moved it to that section
    you will get guidance rather than outright answers
    We expect input from you regarding what you do know/understand about the circuit :)
    davenn, Jan 16, 2018
    #2
    1. Advertisements
  3. michael1978
    michael1978
    Mar 17, 2012
    82
    no is not home study, is just my hobby,
    michael1978, Jan 16, 2018
    #3
  4. michael1978
    Alec_t
    Jul 7, 2015
    2,202
    569
    Wales
    It stores charge.
    What are you trying to do with that circuit?
    Alec_t, Jan 16, 2018
    #4
  5. michael1978
    davenn Moderator
    12,369
    1,494
    Sydney, Australia
    well it is ion the style of homework, so we will treat it as such
    1) where did you get this circuit?
    2) how much of the operation of the circuit do you understand?
    3) what google searching have you done to try and identify what may be happening in the circuit ?
    #5
  6. michael1978
    Cannonball
    May 6, 2017
    79
    26
    SC
    I wish I could help, but I have never seen a circuit like this. I have seen it in an npn circuit used for a signal ground.
    I have never seen it on the load resistor in any circuit. Npn or pnp.
    Good luck with this one.
    Cannonball, Jan 17, 2018
    #6
  7. michael1978
    Ratch
    Mar 10, 2013
    911
    269
    No, capacitors store energy, not charge. A capacitor energized to 1000 volts contains the same net charge as one with no voltage across it. For every charge carrier that enters a capacitor, a matching charge carrier leaves it.
    Ratch
    Ratch, Jan 17, 2018
    #7
    davenn likes this.
  8. michael1978
    7,943
    1,447
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    Looks like you're trying to simulate a common base circuit, but then R1/C1 need to go to a positive supply, not ground.
    But I have no clear idea what C1 is good for. It will decrease the collector impedance for higher frequencies, thus lowering gain.
    Are you trying to change the frequency response? It would really help to know where you git that circuit from. Obviously you haven't made it up yourself, otherwise you'd know what C1 is good for.
    Harald Kapp, Jan 17, 2018
    #8
  9. michael1978
    michael1978
    Mar 17, 2012
    82
    to tell you the truth, nothing just i want to know, how its work, i know that in ac capacitor only discharge and charge, but i see in one site this and i was liking to know how it working, of this connection dont exist
    here the site
    https://electronics.stackexchange.c...r-in-a-bjt-collector-with-a-parallel-resistor
    michael1978, Jan 17, 2018
    #9
  10. michael1978
    michael1978
    Mar 17, 2012
    82
    you mean the capacitor dry the collector resistance?
    #10
  11. michael1978
    michael1978
    Mar 17, 2012
    82
    you mean does not exsist such a connection?
    #11
  12. michael1978
    michael1978
    Mar 17, 2012
    82
    #12
  13. michael1978
    michael1978
    Mar 17, 2012
    82
    here i get
    and i will like to know how its work, or maybe dont exist such connection
    #13
  14. michael1978
    Alec_t
    Jul 7, 2015
    2,202
    569
    Wales
    Is this article wrong then, Ratch? Q=CV, so for a given C the charge and voltage are proportional. Energy E = CV^2/2.
    Alec_t, Jan 17, 2018
    #14
  15. michael1978
    Alec_t
    Jul 7, 2015
    2,202
    569
    Wales
    Eh?
    #15
  16. michael1978
    Cannonball
    May 6, 2017
    79
    26
    SC
    Yep
    #16
    michael1978 likes this.
  17. michael1978
    7,943
    1,447
    There's one big difference: The original circuit uses a DC input source, not AC as you do.
    In the original circuit the transistor, the voltage source and teh 2.5 k and 5 k resistors make a constant current source which in turn charges the 1 μF capacitor. The question is, how long it takes to charge the capacitor and what will be the final voltage across the capacitor is a 1 k resistor is parallel to the capacitor.
    Honestly, I don't know why you are asking here as the are answers on the original website. If you do not understand then please ask specifically for the points that are unclear instead of letting us guess.
    #17
  18. michael1978
    Ratch
    Mar 10, 2013
    911
    269
    Yes, it is wrong, as are so many articles on how capacitors work. Anytime you hear someone saying a capacitor or battery being "charged", that is wrong. The battery does not transport charge from one plate to the other. The capacitor separates charge by accumulating charge carriers on one plate and depleting an equal number of charge carriers on the opposite plate. No charge goes through the capacitor dielectric. The charge carriers that accumulate on one plate are not the same charge carriers that are removed from the other plate. Separating the charge causes an electric field to form and stores energy. The net charge change is always zero. Therefore, capacitors become charged with energy, not charge. It is correct to say that capacitors are energized, not charged.
    Ratch
    Ratch, Jan 17, 2018
    #18
    davenn likes this.
  19. michael1978
    7,943
    1,447
    @Ratch : your signature expresses it perfectly ;)
    I totally agree that you are right in a physical sense as any charge on one electrode is compensated by an equal charge of opposite sign on the opposite electrode; and energy is stord in the electric field between these electrodes.
    Nevertheless it is common usage to handle capacitors as "charge storage" elements. This is reflected in the definition of capacitance as C = q/V (Wikipedia). This is simply a convenient way for handling capacitance in the context of circuit analysis and design.
    While you are physically correct, I doubt this helps the op understanding the problem. With the above definition it is comparatively easy to see that V = q/C and with q = integral (i(t) dt the problem can be solved. Regardless of the physical fact.
    #19
    Tha fios agaibh likes this.
  20. michael1978
    23,541
    2,179
    Ratch, I find the errors in your post so egregious that I am forced to ignore it all.
    So many people write "say" when they more accurately mean "write", and "hear" when they mean "read".
    There is no sound involved in most of this communication, so "hear" and "say" should be an anathema to anyone who prides themselves on literal accuracy. Words clearly have only a single meaning, independent of context, and I appoint myself sole arbiter of the correct meaning.
    Instead of "write" or "say", one should instead use "impart".
    Instead of "hear" or "read', one should substitute something like "receive" or "perceive".
    If people continue to use words I understand but feel are not perfectly accurate, I will argue their use, deflect the conversation, and bring attention to my pedantry.
    :-D
    (*steve*), Jan 17, 2018
    #20
    Tha fios agaibh and Harald Kapp like this.
    1. Advertisements
Thread Status:
