I have an elderly neighbor who likes to work in his garage, and likes it
warm. He's had a kerosene heater and now a propane heater. He's not entirely
happy with the price of the fuel. If I were in his shoes, I wouldn't want to
driving back to the h/w store every few days or week to get more fuel. I
think he might be better off with electric. I checked at the local h/w
store, and they have a quart heater. Don't know much about them. Are they
more efficient than non-quarts. The h/w guy said he used two Holmes large
quartz headers (1875 watts) to keep his garage warm. Comments.
Wayne T. Watson (Watson Adventures, Prop., Nevada City, CA)
(121.015 Deg. W, 39.262 Deg. N) GMT-8 hr std. time)
Obz Site: 39° 15' 7" N, 121° 2' 32" W, 2700 feet
Among the safest heaters are the ceramic element electrics with a fan.
Nothing gets hot enough to glow red, so the case can be plastic
(totally insulated).
I look at heating a work area in the same way I look at lighting it -
if task lighting is appropriate, then so is task heating. Although
it's the traditional way of heating workapaces, there's little point
in heating a 20x20 space if your work area is 5x5 (less than 10% of
the total area).
I use a 1250/1500 watt fan forced ceramic unit to heat a small area
(just where I'm working) in a two-car garage. The thermometer on the
inside wall might rise to a temperature of 50F or so, but it's
appreciably warmer in the 5x5 space in which I'm actually working.
And remember not to sit on the concrete floor - two layers of
cardboard between your body and the floor will make a big difference
in your comfort level.
It probably helps that I've worked on reducing air infiltration in the
garage - replaced the rotting wood doors with insulated doors that
have weather stripping all around, put storm windows on the two
windows in the garage, etc.
I've used a kerosene heater for emergency heating (a piece of my Y2K
preparations that saw use in January of 2000, along with the Coleman
stove & lantern and a couple of oil lamps). I think the heater is in
the range of 22000-28000 BTU and uses about 2 gallons/day (waking
hours only) to keep 1000 sq.ft. bearable in below-freezing weather.
Heating with kerosene doesn't smell very good, but it's better than
being cold.
The price of fuel is VERY dependent on the supplier and the packaging.
If you can manage a 55 gallon drum (about 500lb when filled), then
I've seen 55 gallons of kerosene for $100. The local Home Depot has a
5 gallon can of kerosene for $34.95. The local Ace Hardware has
kerosene for $2.99/gallon if you provide the container. I don't think
that can is worth $20 ;-)
John
