A
Alex Rast
I have an FPGA-based prototype for a PCI product in development. Since the
intended product application will involve very high speed data transfers,
we have designed all the I/O and internal busses in the FPGA to work on
synchronous protocols. Now, however, I'm running into a real stumbling
block.
The problem is in testing the board. What I need to do is to be able to
generate some test data on a PC, and send it to the FPGA, simulating data
flow through the system under test. Similarly, the PC needs to be able to
receive test data from the FPGA. Because of the design of the board, I need
to use a synchronous, hardware-based protocol and interface to transfer the
data.
However, there doesn't seem to be much hardware out there that will enable
me to do this, at least not at reasonable cost. All I need to do is dump
bitstreams in either direction, synchronously, but I have met with little
success. We made an abortive effort to use LabView together with their DIO-
32HS, which seemed promising and (supposedly) offered a high-speed
synchronous protocol, but when we tried to use it, the protocol didn't
work, we couldn't make it work, and apparently nobody at National
Instruments had tried using that protocol and gotten it to work. Indeed, I
saw others posting on the Labview NG, running into the same problems! So
that's not an option.
So, what would be the easiest way to create a test interface that lets us
transfer data using a synchronous protocol at reasonable speeds (at least
10 MHz) between a PC and a device under test? Our prototype board has no
shortage of high-speed, MICTOR connectors that we can use to interface to.
We're willing to spend some dollars to do it, but if it starts escalating
into the thousands of dollars just to get a simple test interface, I think
that such a price is disproportionate relative to what we need to achieve.
So I think a fair budget limit is around $2000. Any suggestions?
block.
data.
