Jonathan Leppert
I'm designing a high current H-bridge to provide power to a thermoelectric
cooler/heater. I have selected the International Rectifier IR3221 high side
switch along with the suggested MOSFETs to form a low footprint H-bridge.
However, it has some type of provision to start DC motors (its intended
application) in a kind of soft-start mode, variable by some type of PWM. I
really don't need this feature and in fact I'm confused by the explanations
for it in the datasheet. Is there any way to bypass this -- in the example
application circuit and demoboard they have all kinds of extra components
for this feature. If anyone could give me an idea on what exactly this is,
and what I can do with that pin (ss) as far as what it needs for the device
to work properly. All I need is to be able to switch a current source on and
off and to change the polarity with this H-bridge, what would be the
simplest circuit using this device to do that? Is this even the best way to
go about all this?
The data sheet for the IR3221 can be viewed below:
http://www.irf.com/product-info/datasheets/data/ir3221.pdf
Jonathan
go about all this?
Jonathan
