Good, economic epoxy mixer?
Discussion in 'Project Construction Technologies' started by primuspaul, Jul 30, 2018.
  1. primuspaul
    primuspaul
    Feb 7, 2018
    74
    Can someone recommend a good, economical epoxy mixer/dispenser? I bought about a quarter of a gallon of 24 hour epoxy and need to use it for small repair projects. Unfortunately, I have trouble getting the right 1:1 ratios when mixing.
    #1
    1. Advertisements
  2. primuspaul
    kellys_eye
    Jun 25, 2010
    3,611
    960
    West Coast, Scotland
    Measuring cups? Two identical cups, each 'full' will always equal a 1:1 ratio.
    Syringe (for smaller amounts).
    Bigger cups (for larger amounts)
    ANY two cups that are half the capacity of the total mix you need would do it.
    kellys_eye, Jul 30, 2018
    #2
    1. Advertisements
  3. primuspaul
    dave9
    Mar 5, 2017
    354
    85
    Clear plastic medicine/pill cups, with the markings on the side. Example:
    https://www.amazon.com/HomEquip-Graduated-Medicine-Non-Sterile-Disposable/dp/B01MZ64XGJ
    https://www.amazon.com/Dynarex-4252-1-Medicine-Polyethylene-Count/dp/B01N6MXK13
    Similar cups come in larger sizes too but often don't have the markings on them. In that case measure half the quantity in water, pour it in and use a marker to draw a line at that level, then add that much water again and draw a second line.
    However, and this is more of an issue with faster setting epoxy, it is exothermic as it sets so having it in a small surface area vessel will make it cure faster than if it were spread out more.
    [​IMG]
    dave9, Jul 30, 2018
    #3
  4. primuspaul
    Bluejets
    Oct 5, 2014
    2,649
    501
    This HAS to be a windup.....:rolleyes:
    Bluejets, Jul 31, 2018
    #4
  5. primuspaul
    primuspaul
    Feb 7, 2018
    74
    I'll have to try this since using the 2-cup method the donor cup always retains some residue and I end up with an unequal mixture. I think that and 2 syringes should do it.
    primuspaul, Jul 31, 2018
    #5
  6. primuspaul
    FuZZ1L0G1C
    Mar 25, 2014
    268
    91
    Johannesburg North-East
    2 identical gradated measuring vessels, each with a maximum of full capacity required.
    One half full (A).
    The other Half Empty (B).
    Mix A to B and stir thoroughly.
    Apply and allow to set at least 24 hours.
    FuZZ1L0G1C, Aug 6, 2018
    #6
    1. Advertisements
