R
Ross Herbert
On Mon, 29 Dec 2008 16:07:31 -0900, [email protected] (Floyd L. Davidson) wrote:
:>"Floyd L. Davidson"
:>> Eeyore
:>>>> Historically they *all* had such a transformer, and even
:>>>> today many of them do (it's cheap).
:>>>Transformers are not cheap and I haven't ever seen a phone with one in,
:>>>even
:>>>going back 30+ years. There's simply no need.
:>> Get a diagram of any given telset you wish that works
:>> without active components (amplifiers), and you *will*
:>> find a transformer.
:>> And trust me, they *are* cheap!
:>> Going back 30+ years, they *all* had transformers.
:>** But not the 1:1 matching/ isolating kind the OP asked about - dickhead.
:I'm sorry, but the nickname your mother uses for you is
:not appropriate in reference to other people.
lease not that I have not said it is a matching
:transformer, nor have I said that it is necessarily
:appropriate for the OP. All I did was properly describe
:what it actually is.
:> The " hybrid " circuit couples the earphone and mic to the line but is
:>generally not even isolating.
:Wrong again. It provides isolation. As I mentioned in
:another post, a POTS loop needs to isolate the VF signal
:from the DC signal, and also to isolate the transmit
:signal from the receive signal.
:It's primary purpose is isolation. It does not provide
:impedance matching (in typical telsets, though I assure
:you there are special ones that do have exactly that
:function built into the hybrid network).
I have to agree with Phil on this one. The so called "transformer" you are
referring to in a POTS telephone is NOT for isolation at all. In fact in its
main function is to act as a hybrid matching transformer. Most of these
transformers will have 3 inductive windings and may also include non-inductive
windings to act as resistors (such as for the balance arm of the hybrid). The
windings are not generally galvanically isolated from one another and the device
generally conforms as a type of "auto-transformer".
Here is some text from an old BPO training document which describes the function
of the hybrid transformer in a POTS telephone. Despite it being old doesn't mean
that the theory is outdated. Incidentally, the schematic included shows all 3
windings connected in series, ie. NOT galvanically isolated.
QUOTE:
It is only possible for the transmitter, receiver, and line of a telephone
circuit to be interconnected so that each is electrically matched to the
remainder of the circuit, thus ensuring maximum transfer of sent and received
power, when an additional power consuming impedance is included in the
circuit. The power consuming impedance is termed a 'balance'.
The sense of the three windings of the induction coil and the electrical
characteristics of the other components are such that, ideally
(a) when transmitting, the output power is shared only between the line and
balance,
and;
(b) when receiving, the output power from the line is shared only between the
receiver and the transmitter.
UNQUOTE
:>> Eeyore
:>>>even
balance,
and;
UNQUOTE
