Gerbv-2.6.1
R
Robert Baer
Does not work.
"Procedure entry point freeaddrinfo not found in WS2_32.dll"
L
Lasse Langwadt Christensen
Den tirsdag den 19. november 2013 00.30.36 UTC+1 skrev Robert Baer:
Does not work.
usually means the dll is an old version from before that function was added,
you wouldn't happen to be running some ancient OS that hasn't been or can't
be kept updated ?
-Lasse
R
Robert Baer
be kept updated ?
-Lasse
I use Win2K, with the latest roll-up (made it SP5); this Baer growls
that is as far as it goes in updates.
Gerbv-2.4.1 has same exact problem.
So, is that dll available for Win2K, or is there a version of Gerbv
that will run in Win2k?
Thanks.
Does not work.
To execute an application using this function on earlier versions of Windows (Windows 2000, Windows NT, and Windows Me/98/95), then it is mandatary to#include Ws2tcpip.h and also Wspiapi.h. When the Wspiapi.h header file is included, the 'getaddrinfo' function is #defined to the 'WspiapiGetAddrInfo' inline function in Wspiapi.h. At runtime, the 'WspiapiGetAddrInfo' function is implemented in such a way that if the Ws2_32.dll or the Wship6.dll (the file containing getaddrinfo in the IPv6 Technology Preview for Windows 2000) does not include 'getaddrinfo', then a version of 'getaddrinfo' is implemented inline based on code in the Wspiapi.h header file. This inline code will be used on older Windows platforms that do not natively support the 'getaddrinfo' function.
Microsoft KB article http://support.microsoft.com/kb/955045
Found via Google as "I Feel Lucky" in 0.01 seconds.
R
Robert Baer
To execute an application using this function on earlier versions of Windows (Windows 2000, Windows NT, and Windows Me/98/95), then it is mandatary to #include Ws2tcpip.h and also Wspiapi.h. When the Wspiapi.h header file is included, the 'getaddrinfo' function is #defined to the 'WspiapiGetAddrInfo' inline function in Wspiapi.h. At runtime, the 'WspiapiGetAddrInfo' function is implemented in such a way that if the Ws2_32.dll or the Wship6.dll (the file containing getaddrinfo in the IPv6 Technology Preview for Windows 2000) does not include 'getaddrinfo', then a version of 'getaddrinfo' is implemented inline based on code in the Wspiapi.h header file. This inline code will be used on older Windows platforms that do not natively support the 'getaddrinfo' function.
I do not speak "C" and we do not get along with each other, so cannot
do a "build" as you seem to imply.
I poked around and 2.2 works.
Thanks.
R
Robert Baer
Robert said:
I do not speak "C" and we do not get along with each other, so cannot do
Thanks.
OOPS!
The program opens, and wants non-existent projects; not useful that way.
Drag a Gerber file to the gerbv srtcut and bam! damn enry point in
dll missing.
So ver 2.2 does not work.
No un-install, so i guess i will have to brute force rip it out,
along with ghosts of 2.4 and 2.6 as well.
Jasen Betts
Thanks.
possibly if you compile it yourself. OTOH I don't recall it having any
network functionality, I wonder what it needs ws2_32 for.
U
Uwe Hercksen
John said:
You should consider upgrading to a modern OS, like Windows XP.
Hello,
it is some years ago when XP was modern....
Bye
S
Spehro Pefhany
Has not support for that just ended?
April 8, 2014 for both XP SP3 and Office 2003. I don't expect it will
suddenly stop working on April 9.
Best regards,
Spehro Pefhany
R
Robert Baer
I cannot use all of the functions of my computer with XP or "better"
because there are no drivers for the video capture card, or the sound
card, or the Ethernet card, or USB functions for my flatbed scanner or...
I am not about to throw away hundreds of dollars of perfectly good
hardware JUST for one or two stupid programs.
R
Robert Baer
Ask Microsoft; they create crazieness with their ugly OSes.
R
Robert Baer
See my other response WRT XP.
BTW, isn't "support" for XP going to die sometime next year?
L
Den tirsdag den 19. november 2013 12.04.46 UTC+1 skrev Spehro Pefhany:
it won't stop working but newly found security hole will not be closed,
so yeh, it will probably be april 10 before they all become part of a botnet
only hope is that it becomes rare enough that no one bother to find any holes
-Lasse
S
Spehro Pefhany
-Lasse
I hope that few of us depend for our security on Microsoft OS
updates..
--sp
No, AAMOF, M$ has announced that it will release a key that will allow
it to function forever without calling home to Redmond. I wouldn't be
surprised to see support extended further, either.
josephkk
Actually yes you are. Maybe not today but eventually when nobody can find
or create a machine that will run the antiques. And by the way, they have
depreciated below zero value already. You will have to pay someone to
haul them away for you, especially since they are already effectively
useless. Get used to donating your old stuff while it still has value.
And if you need real longevity look as buying SCADA oriented hardware; 19
times the price of ordinary stuff; your choice.
M
miso
-Lasse
Rare? It is bootlegged everywhere in the 3rd world. It doesn't have all
that phone home spy stuff you find in win7 on up.
Win7 has an XP VM. You have to download it. It is not to be confused
with the XP compatibility mode.
I really don't see a need to be running XP once it is no longer
supported. That said, if you take the PC off the internet, you can keep
it around for whatever task needs XP. I do realize people have software
or devices that are legacy.
R
Robert Baer
SCADA??? With all of the bugs and malware running around??? Are you
crazy? Telling me to jump from the frying pan into the fire?
L
Den torsdag den 21. november 2013 09.13.21 UTC+1 skrev Robert Baer:
just because the SCADA software might be screwed up (or atleast not robust when exposed to determined hackers) it doesn't mean that the hardware isn't build to last and be availablel forever
-Lasse
josephkk
Your response does not make sense. Hardware build for SCADA has 20 to 40
year lifetimes, no ordinary computer does nearly as well. Likewise
computers built for SCADA connection have 10 to 20 year lifetimes. You
can still get ISA computers for that purpose, but they cost a lot more
than current lowest price stuff popular today. Your choice.
Similar threads
R
Replies
15
Views
2K
Robert Baer
R
S
Replies
Views
2K
Stuart Brorson
S
S
Replies
14
Views
3K
John Devereux
