S
Stuart Brorson
Hello!
This is to announce the release of gerbv-2.1.0! Gerbv is an open
source
Gerber file (RS-274X only) viewer for Linux and other unix flavors.
Besides
viewing Gerbers, you may also view Excellon drill files as well as
XYRS
(pick-place) files. For more information, browse to gerbv's web site:
http://gerbv.sourceforge.net/
Gerbv is allied with the gEDA Project, an open-source collaborative
which has produced an end-to-end tool chain for PCB design on Linux
and
other unices. The gEDA Project's website is here:
http://geda.seul.org/
Gerbv release 2.1.0 introduces several new features. Here is
a list of new features:
* Added ability to select objects, with the option of deleting or
viewing
basic properties of the objects
* Split off the core functionality of gerbv into a library (libgerbv)
to
allow developers to quickly write software using Gerber
parsing/editing/exporting/rendering functionality. Full DOxygen
documentation has also been created to facilitate developers wishing
to use
libgerbv.
* Added export to RS274X and Excellon functionality, allowing gerbv
to
translate files between formats. The RS274X export function can also
be
used to "clean" troublesome files to a more compatible format.
* Added the ability to override the Excellon format "guessing",
allowing
non-standard drill files to be correctly rendered
* Greatly expanded the command line functionality, including the
ability to
panelize boards into a single one through the command line
* Added "Aperture usage" tab to Gerber reports. This allows the user
to
see how often each aperture is used in all visible layers of his
project.
Several notable bugs were squished in release 2.1.0:
* Fixed bug when exporting several layers to SVG/PDF/PS, which caused
corrupted output and/or crashes
* Fixed several Windows-only problems related to parsing and
rendering
* Fixed rendering bug when using polygon objects within step and
repeat
blocks
* Improved RS-274X export output format to work with certain Gerber
viewing
software
Gerbv's homepage is on SourceForge:
http://gerbv.sourceforge.net/.
There you will find a bug database, a feature request database, the
CVS repo
and a commit mailinglist.
To download gerbv-2.1.0, go to
http://prdownloads.sourceforge.net/gerbv/
and grab gerbv-2.1.0.tar.gz
To install gerbv do this:
1. tar zxf gerbv-2.1.0.tar.gz
2. cd gerbv-2.1.0
3. ./configure
4. make && make install
Interesting configure options are:
--help : Lists all configure options.
--enable-debug : Program will output lots of debug spew while
running
(default = no -> no debug output by default.)
--disable-exportpng : Disable compilation of export of PNGs.
(default = no -> exportpng on by default.)
--enable-unit-mm : Set default unit for coordinates in status bar
to mm
(default = no -> units = inches by default.)
--disable-cairo : Use GDK only for graphics rendering.
(default = no -> both GDK and cairo used by
default.)
--enable-efence : Link with ElectricFence for malloc debugging
(default = no -> efence off by default.)
--disable-update-desktop-database
: Update desktop icon database after installation
(default = no -> desktop icon installed by
default.)
Thank you for using gerbv-2.1.0!
-- The gerbv team
source
Besides
XYRS
and
viewing
to
to use
libgerbv.
to
be
allowing
ability to
to
project.
rendering
repeat
blocks
viewing
software
CVS repo
2. cd gerbv-2.1.0
3. ./configure
running
to mm
default.)
default.)
-- The gerbv team
