Joerg
Hello,
Just kicked the tires on gschem, to see if I should switch. Since it
doesn't look like there will ever be a Windows version I am running it
in VirtualBox on an XP machine. Looks pretty good so far. Anyhow, a
question:
People like me must include schematic excerpts in documents a lot. When
I use the "Write image" export utility it does produce a file I could
then import but the resolution isn't adequate for a decent quality
document. At large width and height settings it's actually so chopped up
that parts values cannot be deciphered anymore. In Eagle I could set a
resolution instead of width and height and when set to 300 that produces
a pristine PNG image.
Is that possible in gschem somehow? Or if not are there any plans to
improve the "Write image" routine? Alternatively, is there a trick to
store the whole sheet in a somewhat popular format (preferably not PDF,
PS or EPS) and then use another graphics program to pick out the wanted
piece?
question:
piece?
