Hi everyone!
My gate automation system doesn't work properly. The gate has two motors, you can see one of them in the picture below and the automation system is a BFT, the motherboard is an
ARIES and where I believe the problem is. The manual for the motherboard is this www.
bft.cz/privat/navody/ridici_jedn/en/
ARIES.pdf
- During the opening phase, the two motors work correctly and the gate opens.
- During the closing phase one motor keeps opening; the second doesn't do anything.
Everything else seems to work properly (photocells, etc... ). I switched the board connections of the two motors and the behavior switched too, so it is not a problem of the motors.
The problem seems to be very simple but I cannot figure out which component can cause this bad behavior.
What I did:
- I changed the 4 relays (k2, k5, k3 and k7) that seemed to be damaged with new ones...but the old ones were actually working correctly
- I changed the two big capacitor, but nothing changed.
- In Y1 (maybe it is more clear in the pictures below) there is a Microcontroller Philips P87C750EBPN (with a label on top "POLLUCE v.ersion 2.51) that I guess is the "brain" of the board, and probably it is not damaged. In fact, I found in my garage an old board that was substituted many years ago. So, I took from the old board the microcontroller and I put it in the installed board and the gate didn't open nor close (it only clicked when the button was pressed).
Then I installed the old board WITH the microcontroller of the newer one and the gate opened and closed a couple of times...then stopped completely (I deduced that the old board had some additional issues, not only the broken microcontroller).
Can you understand from the pictures above and in the link below what component could cause this problematic behavior during the closure phase?
Thank you in advance for any suggestion.
In the link below, you can find a gallery with pictures of the board, I hope you can easily see how it works:
http://imgur.com/a/m8Mh2
Please let me know if you need more details/pictures to discover what is the issue.
