Lawrenciumbc
- Nov 2, 2015
- 41
- Joined
- Nov 2, 2015
- Messages
- 41
I am new to electronics and just trying to get my head around the use of function generators. I understand that they are used in labs to generate signals for testing, but are they more like a microphone for example which picks up an audio wave and sends it into a circuit (i.e. nothing to do with power) or are they more like a low power supply for AC?
My question is more about how I should think of them within a circuit and whether the peak to peak voltage is just additional voltage into the circuit on top of my power supply.
The particular context is that I am learning about transistor biasing (for a LiFi transmitter) and I have a 5V VCC going into the circuit at the collector of my transistor (via an LED which is also voltage divided to the base too) and then a function generator going to the base which supplies a wave (5Vpk) which will just switch the transistor on and off and I am confused as to whether and the how the peak to peak voltage contributes to the circuit.
