Full-wave rectifier Smoking Issue
Discussion in 'General Electronics Discussion' started by BASICFreak, Jan 30, 2014.
  1. BASICFreak
    BASICFreak
    Jan 30, 2014
    14
    Livingston, LA, USA
    Bridge Rectifier model: KBP5010
    Microwave Oven Transformer rewired to put out 6VAC
    Okay, this rectifier is ratted at 1000V 50A and I'm running After rectifying and load 4.4V and between 10 and 15 Amps, but within a minute the rectifier will start smoking, if I am not careful this will be the third one I've been through.
    I reapplied the thermal paste hoping there was too much, no luck.
    The transformer is directly into the AC poles of the rectifier
    A 30A fuse on Positive Pole
    I have a 2200uF 50V Capacitor between the Positive and Negative
    Then from there I'm going into an HHO cell.
    I took video of this and uploaded it to YouTube if it helps you to see what I'm talking about
    Also hand drew a small diagram with mspaint I'm attaching
    YouTube video UUfTYxLaJ1I
    URL
    Thanks in advance,
    Brian T Hoover
    P.S. If you need more information I will do my best to supply it.
    #1
  2. BASICFreak
    24,608
    2,490
    To keep it relatively simple, you need a series memristor to reduce RF heating from the inductively coupled plasma discharge emanating from catalysed HHO re-integration on the Brown's electrode(s).
    (*steve*), Jan 30, 2014
    #2
  3. BASICFreak
    BASICFreak
    Jan 30, 2014
    14
    Livingston, LA, USA
    This is the first post on two forums that makes any sense.
    We're talking about the flux capacitor looking thing:
    http://letstalkaboutscience.wordpress.com/2012/09/17/what-is-a-memristor/
    If so, I'll look into it and return with results,
    Brian T Hoover
    BASICFreak, Jan 31, 2014
    #3
  4. BASICFreak
    24,608
    2,490
    Clearly I've been outclassed elsewhere.
    I suspect that you need a larger heatsink. Either that or your voltage and/or current measurements are not accurate.
    Will you eventually burn the HHO to generate power to create more HHO?
    (*steve*), Jan 31, 2014
    #4
  5. BASICFreak
    davenn Moderator
    12,880
    1,641
    Sydney, Australia
    firstly measure your DC current
    secondly once the DC current is known replace the 30A fuse with something more appropriate say 2-3 amps higher than the DC current
    3rdly as Steve suggested, you heatsink is way too small if you are drawing anything over ~5 Amps
    davenn, Jan 31, 2014
    #5
  6. BASICFreak
    BASICFreak
    Jan 30, 2014
    14
    Livingston, LA, USA
    Only person to mention electrical feedback :)
    My voltage is right Amps may not be, I have no way to measure the Amps at that low of a voltage, my gauge has a minimum of 8V max of 48V 100A, I used Ohms law to estimate it:
    300W 10V 30A = 1/3 Ohm (was measured)
    58W 4.4V 13.2A = 1/3 Ohm (calculated/estimated)
    I'm going to try the same trick as a motor controlled by PWM and try to prevent back-surge Only logical guess, other than just using 11.5-13.3V input, but I cannot run it long enough at one time to condition the plates.
    Currently with the HHO I'm running a push mower, soon I hope to have it in my car and (theoretically) increase mileage.
    #6
  7. BASICFreak
    davenn Moderator
    12,880
    1,641
    Sydney, Australia
    Yes you do ... low voltage has nothing to do with not making a current reading
    for a start you need to estimate the current by dropping that 30 Amp fuse to 10A
    and see if it blows
    if it does, try a 15A fuse, if it doesn't blow then you have narrowed down the current to between 10 and 15 Amps .... easy :)
    IF a 10 A fuse doesn't blow, then put you multimeter to DC10A and put it series with the positive lead from the rectifier to the cell and measure the current
    cheers
    #7
  8. BASICFreak
    BASICFreak
    Jan 30, 2014
    14
    Livingston, LA, USA
    I guess let me rephrase I don't have a way to do that (currently) only other fuse I have on hand is 1.5amp
    Until then I got two heatsinks I can put together into one to try to reduce heat
    But either way I cannot see how it can be smoking when I can still hold it tightly in my hand, without discomfort
    P.S. I just read your first post lol you posted after I started my last reply and once I submitted I had to leave
    #8
  9. BASICFreak
    24,608
    2,490
    Don't waste too much time, money, or effort on that one.
    #9
  10. BASICFreak
    Arouse1973 Adam
    Dec 18, 2013
    5,157
    1,076
    Cornwall U.K
    Very Good Steve. I was thinking a similar thing
    Arouse1973, Jan 31, 2014
    #10
  11. BASICFreak
    gorgon
    Jun 6, 2011
    597
    21
    Norway
    The bridge will drop 1.1V, at 15A this is 16.5W heat. The Rth value of the heat sink is relative high, so you'll get a high temp fast. Let's be kind and say it is 10 K/W, this is 165C above ambient, at the heatsink. At the silicon it's much higher, around 200C and ready for smoking.
    The drop is 1.1V per leg, I don't know if you need to double that for the circuit, but thats even worse.
    gorgon, Jan 31, 2014
    #11
  12. BASICFreak
    7,280
    1,529
    Worcester, MA
    The irony is about to make my head explode.
    You do realize that Steve's post was a joke, right?
    BobK, Jan 31, 2014
    #12
  13. BASICFreak
    duke37
    Jan 9, 2011
    5,053
    675
    Derbyshire. UK
    The bridge voltage drop will be 2.2V since two diodes are passing the current at any one time.
    Edit
    The bridge must be fitted firmly to the heat sink. You need maximum area and minimum thickness of heat sink compound.
    duke37, Jan 31, 2014
    #13
  14. BASICFreak
    BASICFreak
    Jan 30, 2014
    14
    Livingston, LA, USA
    You do realize my comment was sarcastic right?
    Anyways back on the topic at hand: Trying a larger heatsink later today or tomorrow off a P4.
    I've never had a use for more than 3-5Amp before with a bridge, so I didn't expect heat to rise that quickly.
    #14
  15. BASICFreak
    7,280
    1,529
    Worcester, MA
    I guess your sarcasm was too subtle for me. It looked like you meant it.
    BobK, Jan 31, 2014
    #15
  16. BASICFreak
    BASICFreak
    Jan 30, 2014
    14
    Livingston, LA, USA
    Yea, I've been told that by so many people, I need to find a way to make that more clear...
    Already ruined the drill bit... Time to get one that will get though aluminum...
    #16
  17. BASICFreak
    24,608
    2,490
    Oh, and place the fuse between the transformer and the rectifier, not after the rectifier.
    (*steve*), Feb 1, 2014
    #17
  18. BASICFreak
    BASICFreak
    Jan 30, 2014
    14
    Livingston, LA, USA
    Good point - it was put there to keep my coil from melting in the first place. And obviously if the rectifier goes out and shorts I would be wishing I did that.
    BASICFreak, Feb 1, 2014
    #18
