E
Eli
Hi peaple,
I try to build pspice simulation to a curcuit which I designed in
Orcad. The simulation should be in Frequency domain. In "Simulation
settings" I selected AC sweep option, logarithmic(decade) AC sweep
type.
Start F=10
End F=100k
Points/Decade=100.
Unfortunately the simulation is failed because of the following:
no AC sources - AC sweep ignored.
But AC source is defined(Vsin) ! The only thing I think may be the
problem is the AC source in the Orcade shematics has a defined
frequency. Am I right ?
How can I fix the problem ?
Thanks in advance,
Eli.
type.
Start F=10
End F=100k
Points/Decade=100.
Thanks in advance,
Eli.
