Ed Laughery said:
Hi Alex
Thank you for the heads up on gForth -
Has there been any work done on extending PICForth to support other PIC
chips?
Not similar at all(writen from scratch)
and for 18f only
http://www.freenet.org.nz/pic18forth
pre-pre-alpha version, Pic18Forth-0.0.0
just been announced (on sunday)
writen in python
From the announcement by David McNab
Subject: pre-announcing Forth for PIC18F chips
Hi gnupic and picforth people,
This is a pre-announcement of a coming Forth compiler for the PIC18Fxxx
chips. I've tentatively called it 'PIC18forth', but am open to suggestions
for a better name.
PIC18forth is radically different from the PIC16Fxxx-only PicForth compiler.
Almost nothing in common, since I've written PIC18forth from scratch.
Quick summary of features - love them and loathe them:
* signed/unsigned 16-bit data cells and operators
* software return stack
* data stack grows up (increasing addresses), while
return stack grows down (decreasing addresses)
* total allocated size of data+return stacks can
be set to anything between 16 and 1024 bytes
* compiler is written in Python, and is very approachable
and extensible, even for people new to the code
* integrated into gputils
* forth sources get compiled to relocatable assembly (.asm)
sources, ready for gpasm and gplink
* the generated code embeds a 16-bit forth vm (token threaded
execution model) which executes bytecodes
* the generated code is self-contained, and once assembled
and linked, can be downloaded/flashed as a standalone program
* FSR0 is usually used for data stack ptr, FSR1 usually
used as return stack ptr, FSR2 used as general purpose
pointer
* full support for locals (John Hopkins syntax, data
gets transferred from data stack to a frame on return stack
* vm design favours code density over execution speed
* contents of 'code .. end-code' definitions are included
verbatim in generated assembly source (with '\' comments
changed to ';')
* the defining-words 'primitive .. end-primitive' can be
used in place of 'code .. end-code', to define a word
in assembler which will be available as a single-byte
vm instruction - easy to add/remove primitives at will
* maps to von Neumann memory model, with addresses <8000H
treated as RAM addresses, and addresses>=8000H treated
as program ROM addresses
