Formula for Magnetic field at a distance
Muhammad Umair Khan
Feb 20, 2018
12
Feb 20, 2018
12
How can i mathematically calculate (or represent) a magnetic field at any certain distance from a magnet or a solenoid?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Once you are far enough away, the intensity falls with the square of the distance.
This doesn't work when you're really close.
(*steve*)
25,510
25,510
What about a distance of 3 to 10 cm??? and how does the relation change with it?
It depends. If the magnet (or solenoid) is only a couple of mm in size, then yes. If it's a 20cm cube, then no.
7,682
7,682
Unless you have found a magnetic monopole, it falls off as the cube of the distance (field of a dipole.)
Near one pole, or near a long straight piece of wire carrying a current, it would be inverse square.
Muhammad Umair Khan
Feb 20, 2018
12
Feb 20, 2018
12
Thanks Bob, but could you put it in a mathematical equation please?
