partyanimallighting
- Oct 22, 2012
- 330
- Joined
- Oct 22, 2012
- Messages
- 330
Hi guys,
I have an Antari Z-1200 II fog machine with a problematic remote that continuously outputs once the unit reaches operating temperature. As you can see from the pictures, the unit can be set to output via a timer or continuously or manually. However, the remote is not functioning properly. I've tried another remote and the unit works fine so it's definitely this particular remote that has an issue. The only thing that I found looking a little scorched was zener diode 1 (ZD1). Can any of you wizards out there give me a hand to repair this?
