Fluke 87 LCD display stucked in auto test
Discussion in 'Electronic Equipment' started by Valdemir Santos, Aug 9, 2013.
  1. Hi,
    My Fluke 87 multimeter is stucked in LCD auto test mode.
    I turn on multimeter, and all segments stays on.
    Is there any way to fix this ?
    #1
    1. Advertisements
  2. Valdemir Santos
    Fred Abse Guest
    That's what happens when you switch on with the "AutoHold" button pressed.
    Check for stuck buttons. It can easily happen if you've had the case off.
    Fred Abse, Aug 9, 2013
    #2
    1. Advertisements
  3. Valdemir Santos
    Robert Baer Guest
    Term is "stuckacated", not "stucked".
    Robert Baer, Aug 11, 2013
    #3
  4. Valdemir Santos
    Shaun Guest
    "Valdemir Santos" wrote in message
    I would recommend some percussive maintenance for the meter. Throw it onto
    the floor, that should fix it.
    Shaun, Aug 12, 2013
    #4
  5. I changed 9v battery, and it´s working fine again.
    Fluke 87 is unbreakable !
    Valdemir Santos, Aug 12, 2013
    #5
  6. Valdemir Santos
    Fred Abse Guest
    Stickified?
    Adheserated?
    Fred Abse, Aug 14, 2013
    #6
  7. Valdemir Santos
    Fred Abse Guest
    Battery flag should have come on much earlier.
    Give it to me. I'll break it ;-)
    #7
    1. Advertisements
