I recently moved and at my new place the lights flicker very slightly all the time. At first I blamed the CFL bulbs. In one room I took all those out and put classic bulbs and it seems to be even worse.
The power company said large appliances/heaters are usually to blame and there's no cause for concern unless there's a connection to it being windy.
There's a plug right under the breakers which has its own breaker. I turned off all other but that one and connected a lamp and it still flickers, so the appliances thing isn't the case.
I've got a multi-tester and I was tempted to just turn it to 500V and stick the leads in the outlet, but I'm not quite sure if that's useful or safe?
