Jamie Morken
I used this digital filter design tool:
http://www-users.cs.york.ac.uk/~fisher/mkfilter/
to generate code for a first order Butterworth floating point
low pass filter with 250kHz sampling frequency, and a 100kHz
corner frequency.
This would require a DSP to run on, since I need 6 of these
filters running in parallel, so is there a way to do the same
filtering with fixed point code to run on a microcontroller?
The input values to the filters are fixed point 16bit ADC values.
Can I convert the floating point code to fixed point?
Here's the floating point code that mkfilter generates:
//filter code
#define NZEROS 1
#define NPOLES 1
#define GAIN 1.324919696e+00
static float xv[NZEROS+1], yv[NPOLES+1];
static void filterloop()
{ for (;
{ xv[0] = xv[1];
xv[1] = next input value / GAIN;
yv[0] = yv[1];
yv[1] = (xv[0] + xv[1])
+ ( -0.5095254495 * yv[0]);
next output value = yv[1];
//end of filter code
cheers,
Jamie
corner frequency.
//filter code
#define NZEROS 1
#define NPOLES 1
{ for (;
{ xv[0] = xv[1];
yv[0] = yv[1];
cheers,
Jamie
