FFT of two sine waves added
Anjana_U
Feb 7, 2017
Feb 7, 2017
I am trying to find the fft of 2 sine waves added. The platform used is visualdsp++ and target processor is ADSP BF537. code-
section("L1_data_a")
float inp1[1024];
section("L1_data_b")
complex_fract32 out[1024;
complex_fract32 tw[1024];
fract32 mag[1024];
void main(void)
unsigned int i;
int wst = 1;
int block_exponent;
int scale_method = 1;
int mode=1;
float fs=100.0, f2=10.0, f1=20.0;
float constant= (2*3.142)/fs;
twidfftrad2_fr32(tw, 1024);
asm("nop;");
//--------------------Create frequency samples---------------------//
for(i=0;i<1024;i++)
inp1=(10*sin(constant*f1*i))+(10*sin(constant*f2*i));
asm("nop;");
//------------------fft radix_2 library function --------------------//
rfft_fr32((fract32)inp1, out, tw, wst, 1024, &block_exponent, scale_method);
asm("nop;");
memset(mag,0,1024);
//------------------------Mangnitude calculation--------------------//
fft_magnitude_fr32(out,mag,1024,block_exponent,mode);
asm("nop;");
When mag is plotted(Line plot), peak is obtained at 200. Shouldn't there be two peaks at two different frequencies?
