Fastest Finger First circuit..Help
jvports
Dec 3, 2016
Dec 3, 2016
Hi! I need help with my project. I couldn't understand how the circuit in the picture operates. The ICs used are NE555 ICs and the diodes are 1N4007 diodes. Basically, the circuit works like a two-player quiz buzzer that could be seen in game shows. There are three buttons: one for reset button and two for each player. Once a button is already pushed, the other one is disabled unless the reset button is pushed. Thanks in advance!
73's de Edd
Aug 21, 2015
3,613
Aug 21, 2015
3,613
Sir jvports . . . .
Hmmmmmmmm . . . your fritz . . . just had a fritz . . . .when I tried to mag it up a bit.
So there you have two identical circuits, sitting there, waiting to be triggered.
The trigerring occurs . . .in a FLASH . . . . just as soon as either switches low logic signal derived from that 1K resistor l is switch connected to the top contact of the lucky / fastest switch.
When that occurs that lucky 555 switches to high logic state on its pin 3 output at the far right side, and that supplies a circuit path of power to its LED and it lights up.
SIMULTANEOUSLY its PINK boxed 1N4007 is steering a voltage down to change the state of the switch line so that the other switch will not be able to produce a change at its associated 555.
On reset the circuits are set up to start play again.
73s de Edd
jvports
Dec 3, 2016
Dec 3, 2016
Sir jvports . . . .
73s de Edd
Thanks a lot sir for answering my question! I owe you a lot! I still have questions to ask if it's okay with you. I would just like to know the functions of the three capacitors in the circuit and the 10k ohm resistors too. Thank you a lot sir!
